Guest MKeily Guests Posted 02/08/03 08:29 AM Share Posted 02/08/03 08:29 AM Thanks guys for all the advice and info.Chris and Kevin thanks for your replies.I will get them machined next week then see what Ford's fix is.if this doesn't work I'm going for the DBA's..Cheers all- Mark Link to comment Share on other sites More sharing options...
bdennis Brendan Dennis Member 750 Member For: 22y 2m 9d Gender: Male Location: Melbourne, Vic Posted 03/08/03 09:54 PM Share Posted 03/08/03 09:54 PM I have just done 12,000km. I am starting to get the shudder. I will wait for the 15000km service and hoperfuly they have the fix done by then.. Link to comment Share on other sites More sharing options...
Cobra potty trained Lifetime Members 1,938 Member For: 21y 7m 28d Gender: Male Posted 04/08/03 12:55 AM Share Posted 04/08/03 12:55 AM going up again for an on-car machine .... last one, after that they said they'd replace it ... with what? the same .... struth Link to comment Share on other sites More sharing options...
Falchoon I see red Member 5,758 Member For: 22y 7d Location: nowhere in particular Posted 04/08/03 12:58 AM Share Posted 04/08/03 12:58 AM Is it just the front rotors that are affected or are the rear warping too? Link to comment Share on other sites More sharing options...
richdave SLOJAM, Gone but not forgotten Lifetime Members 1,841 Member For: 22y 2m 13d Gender: Male Location: Outer east - Melbourne Posted 04/08/03 01:10 AM Share Posted 04/08/03 01:10 AM Is it just the front rotors that are affected or are the rear warping too?Only front as far as I know.FWIW - Mine went in today for treatment........done 15,000km Link to comment Share on other sites More sharing options...
1axr TEAM BLUEPRINT Member 913 Member For: 21y 10m 19d Location: Perth W.A. Posted 04/08/03 02:40 AM Share Posted 04/08/03 02:40 AM mine starting to come back again, third time.taking it in for 15000km service at the end of the month.hope ford have found there fix by then. Link to comment Share on other sites More sharing options...
richdave SLOJAM, Gone but not forgotten Lifetime Members 1,841 Member For: 22y 2m 13d Gender: Male Location: Outer east - Melbourne Posted 04/08/03 11:10 AM Share Posted 04/08/03 11:10 AM Mine went in today for treatment........done 15,000km Now they are smooth as a baby's..... Link to comment Share on other sites More sharing options...
Guest gjconn Guests Posted 05/08/03 06:39 PM Share Posted 05/08/03 06:39 PM Long ago when reading all the grief casued by this, and the number of times people were in and out of the dealer, I decided I didn't want anything to do with this problem. I searched for, and found a great source for the DPA Gold, Slotted and Drilled Rotors and replaced all four on my new T-Ute.If you are interested, I'd recommend contacting Trevor at the contact details below. The rotors were about $160 each.Trevor H Online Performance Autos ph 03 8801 0287 0401 037 947 www.onautos.com.au sales@onautos.com.au It was mail order to my door, prompt, and he kept me informed of my order progress. Also picked up a locking gas cap as ute's don't have locking fuel doors like the sedan.No shudder, great brakes, good look, NO WORRIES!! Link to comment Share on other sites More sharing options...
Guest dbasteve Guests Posted 05/08/03 08:11 PM Share Posted 05/08/03 08:11 PM We are finding that the slotted and/or drilled rotors are not generating shudder because they are aggressive on the pads not allowing build up or wear problems to occur.Obviously the pads will wear a little quicker. but it could be worse as we all know! Link to comment Share on other sites More sharing options...
Benny Member 1,869 Member For: 21y 4m 18d Gender: Male Location: Newcastle Posted 07/08/03 12:21 AM Share Posted 07/08/03 12:21 AM I was just informed a couple of days ago that they have found the solutuion to this ongoing brake issue. The whole problem is the new seal design used around the pistons in the caliper. The new seals used on the BA are not allowing enough roll back on the piston which means the pads are rubbing on the rotor to much when brakes aren't applied. The solution is to replace the shims currently used in the caliper with thinner ones to increase clearance and skim the rotors.Whether this works or not I don't know time will tell.thoughwont make much difference to me because under great advice from dbasteve I've purchased a set of 4000 series rotors with after market pads. Link to comment Share on other sites More sharing options...
