Fuse Box Power Need More How To Find
THEMESHMAN260
Where is the best place to connect in the fuse box to draw about 4amps to run some lighting in my ba xr I am already using the input in the tissue box for other things
I do not wont to go straight from the battery is their a place in the fuse box inside the car that you can use that is easy to place wires to draw power from and placing a fuse to just in case you blow things up .
  • No boost, no bottle, just my foot on the throttle!
  • Member For: 20y 11m 9d
The Cig lighter socket can handle about 20 amps. This is the best high draw spot in the car. I guess you just need to look for the 6mm red wire that will be going into the fuesbox to find a sutiable source.
