ROLMDL role model Member 1,111 Member For: 19y 1m 19d Gender: Male Location: Melbourne,S.E Posted 16/02/07 06:31 AM Share Posted 16/02/07 06:31 AM (edited) RAPHOON said: Why?By resetting the tune?Disconnecting the battery won't change the tune in the car.←note that his std factory tune has no boost aswellthat why I said give that ago to clear the mapand reset it self.to see if they solves the problem Edited 16/02/07 06:32 AM by Black ThundeR Link to comment https://www.fordxr6turbo.com/forum/topic/32566-edit-problems/page/3/#findComment-497830 Share on other sites More sharing options...
86gav 69 - PSI Donating Members 263 Member For: 19y 7m 5d Location: Gladstone QLD Posted 16/02/07 06:41 AM Share Posted 16/02/07 06:41 AM I'd nearly bet my left nut that is an intercooler hose blown offCheersGav Link to comment https://www.fordxr6turbo.com/forum/topic/32566-edit-problems/page/3/#findComment-497834 Share on other sites More sharing options...
BOZZTURBO Donating Members 237 Member For: 18y 9m Gender: Male Location: Melbourne Posted 16/02/07 06:56 AM Share Posted 16/02/07 06:56 AM uder the battery Link to comment https://www.fordxr6turbo.com/forum/topic/32566-edit-problems/page/3/#findComment-497840 Share on other sites More sharing options...
Guest Boony_1981 Guests Posted 16/02/07 08:22 AM Share Posted 16/02/07 08:22 AM 86gav said: I'd nearly bet my left nut that is an intercooler hose blown offCheersGav←Well I thoroughly check all hoses coming off the turbo and intercooler and all seemed to be fine.I even tried the battery disconnect and it is still playing up. Now the car even misses a few times up near the 4000rpm range and it still seems like there is no boost. Looks like it's off to the mechanics next week. Link to comment https://www.fordxr6turbo.com/forum/topic/32566-edit-problems/page/3/#findComment-497872 Share on other sites More sharing options...
built2redline Member 187 Member For: 19y 11m 24d Location: sh*tney Posted 18/02/07 10:06 AM Share Posted 18/02/07 10:06 AM (edited) my car used to do the same thing every time a tune was loaded, but when driven hard the car slowly developed boost over the first 3-4 WOT and then it would be fine.mechanic thought it was the boost controller--nopethe actuator--nopethe wastegate jamming--nopeso we just left it at that as it didnt have any effect after the initial no boost situation Edited 18/02/07 10:07 AM by built2redline Link to comment https://www.fordxr6turbo.com/forum/topic/32566-edit-problems/page/3/#findComment-498386 Share on other sites More sharing options...
Guest Boony_1981 Guests Posted 18/02/07 11:11 AM Share Posted 18/02/07 11:11 AM Well I'll let you all know what the problem was when I get to the friendly mechanics. I'm going to get them to check the spark plugs and boost pressure for leaks. I'm not sure what else it could be.....unless the computer is all screwed up (and I really don't want to take it back to ford to get the factory ECU loaded). Link to comment https://www.fordxr6turbo.com/forum/topic/32566-edit-problems/page/3/#findComment-498422 Share on other sites More sharing options...
O2STOCK Donating Members 607 Member For: 19y 7m 15d Location: Brisbane Posted 18/02/07 11:59 AM Share Posted 18/02/07 11:59 AM Boony_1981 said: Well I'll let you all know what the problem was when I get to the friendly mechanics. I'm going to get them to check the spark plugs and boost pressure for leaks. I'm not sure what else it could be.....unless the computer is all screwed up (and I really don't want to take it back to ford to get the factory ECU loaded).←Flash it back to stock before you take the car anywhere . If the tune is reset to factory not by your flasher, but is flashed by the dealers big troubles $$$ Your flasher will have to be returned to CAPA to be reset.James Link to comment https://www.fordxr6turbo.com/forum/topic/32566-edit-problems/page/3/#findComment-498446 Share on other sites More sharing options...
Boony_1981 Member 32 Member For: 18y 2m 6d Location: Townsville Posted 26/02/07 11:36 PM Share Posted 26/02/07 11:36 PM Well I finally took my car to the mechanics, and after 7 hours on the dyno he could not find the problem. For some reason the car is only getting to 2 psi on boost, once or twice it got up to 5. He changed the spark plugs and pressure tested everything, still no problem found.He suspects that the ECU is corrupt so my car is booked into Ford tomorrow to get the ECU factory re-flashed. The question now is: Who can I get to clear all tunes out of the capa flash tuner and install the generic xr6t tunes? So that when I load a new generic tune my new factory tune gets stored in the flash tuner. Can custom tuners with the capa software do this without having to send it back to capa? Link to comment https://www.fordxr6turbo.com/forum/topic/32566-edit-problems/page/3/#findComment-501600 Share on other sites More sharing options...
crans Member 275 Member For: 18y 11m 27d Posted 27/02/07 12:22 AM Share Posted 27/02/07 12:22 AM Have you tried external boost control?See if you can dial it up yourself Link to comment https://www.fordxr6turbo.com/forum/topic/32566-edit-problems/page/3/#findComment-501622 Share on other sites More sharing options...
Boony_1981 Member 32 Member For: 18y 2m 6d Location: Townsville Posted 27/02/07 01:37 AM Share Posted 27/02/07 01:37 AM crans said: Have you tried external boost control?See if you can dial it up yourself←I'm pretty sure he tried that too..... without success. Even tried new boost solenoid too and that didn't work either. Link to comment https://www.fordxr6turbo.com/forum/topic/32566-edit-problems/page/3/#findComment-501658 Share on other sites More sharing options...
