Guest Boony_1981 Guests Posted 15/02/07 11:16 PM Share Posted 15/02/07 11:16 PM Yeh the power light should flash and the slot you flashed in the light should stay on. Can you feel a power inscrease when you flash in the tune? Do you have a boost gauge?Nesh←I felt no power increase after the flash and the turbo doesn't kick in at all after 3000rpm. Nah, I don't have a boost gauge but I'm thinking about getting one now. Link to comment https://www.fordxr6turbo.com/forum/topic/32566-edit-problems/page/2/#findComment-497665 Share on other sites More sharing options...
LTSBGY Member 259 Member For: 19y 5m 18d Posted 15/02/07 11:26 PM Share Posted 15/02/07 11:26 PM Yeh the power light should flash and the slot you flashed in the light should stay on. Can you feel a power inscrease when you flash in the tune? Do you have a boost gauge?Nesh←I felt no power increase after the flash and the turbo doesn't kick in at all after 3000rpm. Nah, I don't have a boost gauge but I'm thinking about getting one now.←Like the others said, check all the pipes. If everything is ok then perhaps try flashing in another tune p2, p1 or which ever u havnt tried yet. Link to comment https://www.fordxr6turbo.com/forum/topic/32566-edit-problems/page/2/#findComment-497673 Share on other sites More sharing options...
ROLMDL role model Member 1,111 Member For: 19y 3m 25d Gender: Male Location: Melbourne,S.E Posted 16/02/07 02:14 AM Share Posted 16/02/07 02:14 AM mabye your not flashing the tune in the right way.I give you a litle run down how to flash it.1. put the key in the ignition but turn off2. connet the flash tuner into the diagnostic port of the car3. use the select button to pick wihch map eg: F P1 P2 P3 4. once picked a tune hold down the program button for 3sec or so5. once lights start to flash turn the ignition to (dash lights illuminate) but dont start the car,6.once the lights have stop flashing and you have a solid orange light on the map you picked.7. turn the igition off8. remove the OBD-II connector from the disgnostic port9. turn the car on and just let it idle for abit.think that the way it done correct me if iam wrong guys ps. the led light has to be solid. Link to comment https://www.fordxr6turbo.com/forum/topic/32566-edit-problems/page/2/#findComment-497717 Share on other sites More sharing options...
Guest Boony_1981 Guests Posted 16/02/07 03:51 AM Share Posted 16/02/07 03:51 AM Yeah I did all that correctly. I went out and quickly checked all the pipes and they seem ok. I'll take a better look tomorrow and also check under the car. Link to comment https://www.fordxr6turbo.com/forum/topic/32566-edit-problems/page/2/#findComment-497760 Share on other sites More sharing options...
BOZZTURBO Donating Members 237 Member For: 18y 11m 6d Gender: Male Location: Melbourne Posted 16/02/07 03:56 AM Share Posted 16/02/07 03:56 AM empty no tunes ????? Link to comment https://www.fordxr6turbo.com/forum/topic/32566-edit-problems/page/2/#findComment-497762 Share on other sites More sharing options...
Guest Boony_1981 Guests Posted 16/02/07 04:10 AM Share Posted 16/02/07 04:10 AM (edited) empty no tunes ????? ←But flashing it back to factory should have bought back the boost. There must be a boost leak somewhere, I just haven't found out where yet.I did get the boost solenoid maintenance done a week ago by a mechanic, maybe something under the battery is leaking. Edited 16/02/07 04:13 AM by Boony_1981 Link to comment https://www.fordxr6turbo.com/forum/topic/32566-edit-problems/page/2/#findComment-497767 Share on other sites More sharing options...
ROLMDL role model Member 1,111 Member For: 19y 3m 25d Gender: Male Location: Melbourne,S.E Posted 16/02/07 04:10 AM Share Posted 16/02/07 04:10 AM empty no tunes ????? ←possibly no tunes on the boxs.when you conet the tuner into the disgnatic port are all the lights flashing? Link to comment https://www.fordxr6turbo.com/forum/topic/32566-edit-problems/page/2/#findComment-497768 Share on other sites More sharing options...
ROLMDL role model Member 1,111 Member For: 19y 3m 25d Gender: Male Location: Melbourne,S.E Posted 16/02/07 04:12 AM Share Posted 16/02/07 04:12 AM empty no tunes ????? ←But flashing it back to factory should have bought back the boost. There must be a boost leak somewhere, I just haven't found out where yet.←mabye give this ago pop the bonnet open disconnect the battery neg first and leave it for about 20 mins and connect it back up and then turn the car on see how you go. Link to comment https://www.fordxr6turbo.com/forum/topic/32566-edit-problems/page/2/#findComment-497770 Share on other sites More sharing options...
Guest Boony_1981 Guests Posted 16/02/07 04:15 AM Share Posted 16/02/07 04:15 AM empty no tunes ????? ←But flashing it back to factory should have bought back the boost. There must be a boost leak somewhere, I just haven't found out where yet.←mabye give this ago pop the bonnet open disconnect the battery neg first and leave it for about 20 mins and connect it back up and then turn the car on see how you go. ←Righto, I'll give that a go and see. Link to comment https://www.fordxr6turbo.com/forum/topic/32566-edit-problems/page/2/#findComment-497773 Share on other sites More sharing options...
RAPHOON Donating Members 1,776 Member For: 22y 8d Posted 16/02/07 05:48 AM Share Posted 16/02/07 05:48 AM Why?By resetting the tune?Disconnecting the battery won't change the tune in the car. Link to comment https://www.fordxr6turbo.com/forum/topic/32566-edit-problems/page/2/#findComment-497808 Share on other sites More sharing options...
