Guest Boony_1981 Guests Posted 15/02/07 09:58 PM Share Posted 15/02/07 09:58 PM Hi Guys, I have just received my new flash tuner with some tunes. So I went and loaded the 8psi tune and the car seems to have no boost. So I put the car back to factory and still no boost. The car was dyno'd to have 210rwkw before I put in any tunes. Here are a few questions from a newbie, I hope someone can help me out.1. Does it normally take about 1-2 mintues to flash the car? 2. After the flash is finished, is the power light supposed to flash while a solid led lit with the tune you just loaded?3. After the flash is loaded, does it take some time (1 hour or so) for the computer to learn all these new settings and produce 240+rwkw or is it instantanous? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 2m 7d Gender: Male Location: Perth Posted 15/02/07 10:05 PM Share Posted 15/02/07 10:05 PM 1. A BA takes 2 to 3 minutes. a BF 1 to 2 minutes,2.I thought the power and tune number led where both solid once flashed (but im not sure... )3.No the reflash is instaneous. Once you flash tune its in there,its only the trims that take time to learn. Link to comment Share on other sites More sharing options...
mbjunior99 Member 4,359 Member For: 21y 11m 8d Gender: Male Location: Brisbane Posted 15/02/07 10:12 PM Share Posted 15/02/07 10:12 PM Are they generic or custom tunes you have there? Link to comment Share on other sites More sharing options...
Guest Boony_1981 Guests Posted 15/02/07 10:27 PM Share Posted 15/02/07 10:27 PM That's a good question, they are supposed to be custom tunes but I really don't trust the tuner at all. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 2m 7d Gender: Male Location: Perth Posted 15/02/07 10:29 PM Share Posted 15/02/07 10:29 PM (edited) I just reread your post and if you have no boost under the stock tune you may have some other underlying issues thats causing it. Check out all you piping connections under the bonnet. The crossover plenum to throttle body is a good place to start... Edited 15/02/07 10:36 PM by hiddeous Link to comment Share on other sites More sharing options...
mbjunior99 Member 4,359 Member For: 21y 11m 8d Gender: Male Location: Brisbane Posted 15/02/07 10:30 PM Share Posted 15/02/07 10:30 PM In that case it's probably a good idea to find someone that has a good reputation and that you can trust and get tme to sort it out for you. Link to comment Share on other sites More sharing options...
Chooka THE Member Donating Members 1,210 Member For: 19y 4m 25d Gender: Male Location: Melbourne Posted 15/02/07 10:56 PM Share Posted 15/02/07 10:56 PM I just reread your post and if you have no boost under the stock tune you may have some other underlying issues that's causing it. Check out all you piping connections under the bonnet. The crossover plenum to throttle body is a good place to start... ← I would say you have put the 8psi tune in and it has boosted more than normal and blown an intake pipe off. Very common problem and easy to fix, just follow the induction path and make sure none are off, my guess is the intercooler pipe, make sure you tighten all the rest of the clamps too Chooka Link to comment Share on other sites More sharing options...
PumpedUp Member 90 Member For: 18y 4m 16d Location: Mehico Posted 15/02/07 11:01 PM Share Posted 15/02/07 11:01 PM I just reread your post and if you have no boost under the stock tune you may have some other underlying issues that's causing it. Check out all you piping connections under the bonnet. The crossover plenum to throttle body is a good place to start... ← I would say you have put the 8psi tune in and it has boosted more than normal and blown an intake pipe off. Very common problem and easy to fix, just follow the induction path and make sure none are off, my guess is the intercooler pipe, make sure you tighten all the rest of the clamps too Chooka←No doubt, the one under the battery tray. Link to comment Share on other sites More sharing options...
Guest Boony_1981 Guests Posted 15/02/07 11:06 PM Share Posted 15/02/07 11:06 PM Ok, I'll check it out.Does anyone know if the power light should flash when the tune has been loaded? Link to comment Share on other sites More sharing options...
LTSBGY Member 259 Member For: 18y 10m 13d Posted 15/02/07 11:13 PM Share Posted 15/02/07 11:13 PM Yeh the power light should flash and the slot you flashed in the light should stay on. Can you feel a power inscrease when you flash in the tune? Do you have a boost gauge?Nesh Link to comment Share on other sites More sharing options...
