Turbo Oil Supply Screen Cleaning
Ralph Wiggum
  • Into the laaaake
  • Member For: 17y 8m 23d
I found it quite time consuming as space is quite limited. Was easier to take the oil filter off and remove the entire air box assy.
  • Into the laaaake
I wouldnt say its easier, I thought it was quite a sh*t of a job. I needed to pull airbox/oil filter out to get to it from the top and bottom. I put the car up on car stands.
  • Into the laaaake
I honestly dont think cleaning the filter is a good idea, as ive mentioned before, I pulled mine out, cleaned it then checked it under a microscope and it was still blocked. I then put it in the ultrasonic cleaner, tried a few more chemicals then had another look under the scope and there were still metal fragments in there.
I think its either remove or replace. Dont clean.
  • It's All In Your Mind
  • Member For: 21y 4m 8d
I have mine booked in tomorrow to have it removed, but if you say it can't be cleaned properly, then obviously it still catches stuff now I'm wondering replacement or removal?
  • Member For: 17y 1m 19d
Why ? Do you have an auto ?
  • Into the laaaake
Yep, Auto. But to make things worse for myself. My oil pressure sender for my Autometer gauge is T'd into where the stock one is. Its quite a large round sender which is right next to where the filter assy is. So space is fairly limited. I use a deep socket to undo it and a spanner to hold it all, but I need to cut the spanner down, its way to long.
