  • Member For: 20y 2m 1d
Hmmmm so you blew the muck from the screen back into the block?
Edited by RHR
No need to quote above post. USE FAST REPLY
  • Member For: 14y 3m 28d
sure did not sure what my next move is anyideas new turbo new bearings not sure ,does any one no what happens if the turbo blows up does it blow the motor,does the car stop going
Edited by RHR
  • Member For: 14y 8m 21d
Im still tossing up between paying 180 for the earls kit or just removing the filter out of the line and whacking it straight back on. Is the earls kit worth it or should I just save my money and pull it off and put the line back on?
  • Member For: 15y 5m 14d
Car will run but turbo will most likely be seized so wouldnt be good. May smoke by burning oil. Why dont you change the filter?
I've removed mine and no problems at all so far.
Edited by Wenier
  • 4 weeks later...
  • Member For: 21y 4m 19d
I'm a mechanic I've never seen or heard of any turbo car having this filter same as others I work with so I got rid of it today. I got some washers at Ford spare parts and they guy had never heard of what I was talking about and was "suprised they stocked them".. I wouldn't waste my money on a filter kit. Engine oil filter is there for a reason and it's a performance car so your oil should always be clean.
On a hoist with the right tools it will only take 30 mins max including cleaning the threads, taking filter out etc. I reckon I would've lost my s**t if I had to do it on the floor :blush:
  • Carnage on the Garage Floor
  • Member For: 15y 1m 21d
Air box out (five minutes) 24mm long socket with 150mm extension - piss easy on the ground. I've fitted the remote kit for safety but do agree with your comments. With regular oil changes, I don't think it's an issue. But yes, definately don't leave the OEM one in :beerchug:
  • BOOST
  • Moderating Team
  • Member For: 21y 9m 27d
:stupid: The oil is filtered prior to going to the turbo anyway so my in line filter is long gone
  • Member For: 16y 11m 14d
right - I'm going to give this a crack. Took the airbox out this morning for a quick look. At what stage do you disconnect the oil supply pipe from the assembly? What is the easiest way to do this or I'm I missing something simple?
You want to remove the banjo bolt that goes through the supply line, the filter is inside that bolt.
  • Awesome...
  • Member For: 14y 11m 28d
Removed mine completly today, took all of 10 minutes during a service.
Pull of air filter, then use a deep 24mm stock to undo the first part, remove the line then use the 24mm to remove the last piece. Then re asemble.
The line doesnt twist and I saw no need to hold the other half...
