  • Member For: 15y 8m 4d
Is the part number still the same for this new style? how much for the new stye of filter $75ish? Getting the inline filter kit from rapid this week but might get that as well for the better flow or just clean up the old one on the machines at work.
  • Moar Powar Babeh
  • Member For: 19y 9m 7d
Remove the screen from the fitting if your fitting a remote filter kit, other wise your setting yourself up to fail.
The idea behind the the remote/inline filter is too remove the potential restriction of the stock element
  • 570Nm @1800rpm
  • Member For: 21y 9m 8d
Part number for the OEM filter/fitting is SY9P424A.
I got mine from Coventrys and it was about $75. I do not have the part number for the cooper washers on me atm.
h ha ha don't worry about that, I'm thick but not that thick. I think I'll clean up my old one at work, chamfer and polish the edges of every hole on the fitting.
  • 4 weeks later...
  • Member For: 15y 7m 30d
washers p/n is E 832149 S300 they are just 12mm copper crush washers.
book says 8 are required/used
Just picked up (all genuine :innocent: parts) 8 washers, revised turbo filter P/N SY 9P424 A, engine oil filter for 74 clams all up.
Who needs an invoice!
Edited by kane_tools
This is a must to change.
After procrastinating over remove or replace, finally decided to replace.
Boy I'm glad I did. Car with full service history and intermediate changes in between this filter almost blocked at 100k.
Turbo was still getting oil and line clear, filter looked clean but could not blow through it.
Revised filter fitted now I can sleep.
Very easy to do with airbox out.
Anyone in Wollongong need it done PM me.
  • 570Nm @1800rpm
kane_tools, where did you use 8 of those brass washers?
I only need 2 each end of the feed line.
put it this way I have some extras to use next time!!
I just ordered the required quantity out of the parts list.
Bit like wog cooking, better more than not enough..
  • 2 weeks later...
  • Member For: 16y 9m 26d
Im looking at getting an aftermarket oil turbo feed line.Can anyone give me there views of which is the best one?
I was looking at the ones on ebay with the earl filter, for around $180 which sounds reasonable.
but I can remember ETM I think? made one aswell. Also is it worth changing the oem filter holder to the revised one. And will it fit into a BA? also read something about washers I guess ill have to change them to as they are a squash fit.
I was going to read through all the posts but my computer is real slow.
Cheers
