  • 570Nm @1800rpm
  • Member For: 21y 9m 8d
I just ordered a new OEM filter and some cooper washers.
When I replace the filter is it worth pulling the feed line off and flushing it?
  • 570Nm @1800rpm
kevo, I am replacing the entire fitting that screws into the block. Turbo is not making any noises on mine with 100000kms so I'll just replace the filter and fitting.
When I spoke to spare parts they told me that the oil feed filter/fitting was revised and not runs a bigger filter element inside the fitting. I am sure the ETM style setup is better in the long run but I can not justify the cost vs replacing the OEM filter.
Cheers
  • <put funny sh*t here>
  • Member For: 18y 7m 21d
That is correct Goran. The new one I installed into the car had openings around double the size of my old filter. I had photos of the two side by side but its on my computer that died :/
  • 570Nm @1800rpm
Thanks Mike. So they must have revised them quiet late as yours is a BF.
I'll take some pictures when I do mine this weekend and post them up.
  • 570Nm @1800rpm
Finally got around to the turbo oil feed line while I am doing a number of other things. Glad to stay that after pulling the filter and feed line off, neither were blocked and the turbo was getting heaps of oil. This is on a 100000km engine that has been serviced as per Ford service schedule.
Was not as easy to remove as I thought due to the location and lack of access. Would be much easier to do this while the oil filter if off. Also I found using deep sockets works best, I used a 22mm and 24mm deep socket with a short arm shifter that I could get in to hold one nut at a time as I undid them in order.
Here are some pictures of the OEM filter next to the current (revised) OEM filter. Notice the new filter is much larger inside the fitting as well as the feed holes:
I also pulled off the oil feed line to clean it out. The line was not blocked but I blew the oil out and then filled it with carby cleaner and let it sit for 5 min then blew it our with compressed air. Also hit it with some wet/dry and metal polish.
Before:
After:
