Wright'y Member 226 Member For: 21y 3m 12d Gender: Male Location: Darwin, NT Posted 27/02/07 01:11 PM Share Posted 27/02/07 01:11 PM Mine was spotless, but ill do it every 20 thousand even though my engine oil comes out as clean as the stuff that goes in. I over kill with my servicing always have always will. The oil still goes through the oil filter then through the oil gallerys and through the screen to the turbo. So unless you have very crappy oil in your motor, once the screen has been cleaned I would say that 20 to 30 would be way safe. Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/2/#findComment-501974 Share on other sites More sharing options...
Guest Guests Posted 27/02/07 11:03 PM Share Posted 27/02/07 11:03 PM this is an excellent article - well done to hiddeous I'll be looking at doing this as soon as possible. Actually I'll probably be getting someone else to do it first time around but you just never know.cheers Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/2/#findComment-502068 Share on other sites More sharing options...
01txr Member 861 Member For: 18y 5m 14d Gender: Male Location: QLD Posted 03/03/07 04:59 AM Share Posted 03/03/07 04:59 AM CAUTIONI removed mine today and found little buildup, cleaned it and it looked spotless.I then checked it by shinning a bright led light through it, and found that 3 quarters of it was clogged up still.Then I preceded to use compressed air and got it about 3 quarters clean, the last bit would not budge.I fitted new o rings to filter element as old ones had gone rock hard and this is where I had another problem as when sliding in the new o rings fowled with step down diameter where filter sits causing me to damage my fitler (man rrrrr *#^), and yes I lubed o rings before sliding it in. This also was on saturday after midday, ford closed.So what Iam saying is if you don't have access to a compressor and something to disolve any carbon grit buildup don't even bother doing it.You need to be able to see through it or oil won't flow through.Shine the light through from outside & view filter internally for light, if any black spots that will be dirt.Ford at springwood QLD had Quoted me $64 for new filter.I also found it easier to remove air box and access from top not under car as to many things in way. Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/2/#findComment-503630 Share on other sites More sharing options...
mbjunior99 Member 4,359 Member For: 22y 6m 6d Gender: Male Location: Brisbane Posted 19/03/07 12:04 AM Share Posted 19/03/07 12:04 AM Where can you get the sealing washers mentioned in step 5 (Part No: E8321495300). I went to Ford this morning and they didn't have the part number listed Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/2/#findComment-510544 Share on other sites More sharing options...
mbjunior99 Member 4,359 Member For: 22y 6m 6d Gender: Male Location: Brisbane Posted 19/03/07 03:36 AM Share Posted 19/03/07 03:36 AM (edited) Ok, just got off the phone with spare parts again. Slight typo, the part number is E832149S300 rather than E8321495300 if anyone is interested Edited 19/03/07 03:37 AM by mbjunior99 Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/2/#findComment-510625 Share on other sites More sharing options...
mbjunior99 Member 4,359 Member For: 22y 6m 6d Gender: Male Location: Brisbane Posted 23/03/07 08:32 AM Share Posted 23/03/07 08:32 AM Ok for those of you that have done this, perhaps you could give me a hand here. I have located the screen but it's extremely tight in there. Do you need to take the oil filter and oil cooler off? Or just work with the space you have? Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/2/#findComment-512617 Share on other sites More sharing options...
mbjunior99 Member 4,359 Member For: 22y 6m 6d Gender: Male Location: Brisbane Posted 24/03/07 12:18 PM Share Posted 24/03/07 12:18 PM *** Bump ***Anyone?? Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/2/#findComment-513053 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 2m 4d Gender: Male Location: Brisbane Posted 24/03/07 12:23 PM Share Posted 24/03/07 12:23 PM Just get the bro's car as the guinea pig, then it doesn't matter so much what gets f'ed up Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/2/#findComment-513055 Share on other sites More sharing options...
mbjunior99 Member 4,359 Member For: 22y 6m 6d Gender: Male Location: Brisbane Posted 24/03/07 12:24 PM Share Posted 24/03/07 12:24 PM That's always an option I would like to know the answer though Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/2/#findComment-513056 Share on other sites More sharing options...
EZ2CME Formerly XR6NA Member 3,512 Member For: 19y 6m 29d Gender: Male Location: Brisbane Posted 24/03/07 12:24 PM Share Posted 24/03/07 12:24 PM (edited) tab said: Just get the bro's car as the guinea pig, then it doesn't matter so much what gets f'ed up ←Oi don't give him ideas Edited 24/03/07 12:26 PM by EZ2CME Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/2/#findComment-513057 Share on other sites More sharing options...
