XF Falcon <put funny sh*t here> Member 3,365 Member For: 18y 7m 26d Gender: Male Location: Perth, NOR Posted 03/10/08 06:18 AM Share Posted 03/10/08 06:18 AM What I did when I took my turbo and lines off, was to put your accelerator flat to the floor while the car is off, and crank the engine over for about 3-4 seconds, and do this a few times. The car will not start cos your foot is down on the gas. This should get the oil flowing through the lines I think? Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/11/#findComment-744201 Share on other sites More sharing options...
ETM Member 1,194 Member For: 18y 3m 21d Gender: Male Location: syd south Posted 03/10/08 10:02 PM Share Posted 03/10/08 10:02 PM or remove the fuel pump relay 1 Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/11/#findComment-744500 Share on other sites More sharing options...
20pounds Member 180 Member For: 16y 9m 9d Gender: Male Posted 06/01/09 09:32 AM Share Posted 06/01/09 09:32 AM has anyone spoken to garret about this problem I'm sure they had a hand in the development of the turbo systemI heard or read somewhere (maybe on this forum) that they have the filter there cause garret wouldnt warrant there turbos unless ford put it on. Reason bein I beleive is some problem with removing all the sand from the block after casting them.The way I see it is peaple are taking them off and finding small shavings of metal so they are doin there job really.Replaced after a run in period I think they would be fine.Ive done near 50k and I will be changing it at my next service.cheers. Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/11/#findComment-797342 Share on other sites More sharing options...
smoke Member 70 Member For: 19y 9d Gender: Male Location: Brisbane Posted 20/01/09 10:06 AM Share Posted 20/01/09 10:06 AM if you back flushed it with carby cleaner and compressed air (through the turbo line), would that do a similar job (provided you were changing your oil? Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/11/#findComment-806592 Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 17y 15d Gender: Male Location: Earth Posted 20/01/09 10:37 AM Share Posted 20/01/09 10:37 AM You could try, but be very careful with the compressed air.You may cause the screen to collapse. Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/11/#findComment-806624 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 4m 27d Gender: Male Location: SW Sydney Posted 20/01/09 10:41 AM Share Posted 20/01/09 10:41 AM Considering the standard line is solid and has banjo fittings on each end you'd have a hard time getting any decent pressure through it with either the carby cleaner or compressed air. Not too mention the left over carby cleaner that will inevitibly be left in your sump going all through your oil galleries and crank journals. In short - no, don't do it that way. Either do it properly or get rid of it and get a remote filter like the one ETM offers. Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/11/#findComment-806631 Share on other sites More sharing options...
CJ_AK cj_ak Donating Members 5,077 Member For: 18y 4d Gender: Male Location: Ropes Crossing Posted 20/01/09 10:56 AM Share Posted 20/01/09 10:56 AM im interested in peoples opinion on how to prime the oil through the lines before attaching to the new turboim in the same position as 'çivillian'dropped off mt turbo for the ute at gcg to be rebuilt today, hopin to fit this long weekendany ideas guys Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/11/#findComment-806649 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 4m 27d Gender: Male Location: SW Sydney Posted 20/01/09 11:02 AM Share Posted 20/01/09 11:02 AM Take the relay out for the fuel pump, it will turn the motor over which will in turn push oil through the lines and motor, but it won't start the engine and move the turbo too much before it gets fully lubed. They don't need much though, so I don't think you need to be too worried about it at idle speeds Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/11/#findComment-806656 Share on other sites More sharing options...
CJ_AK cj_ak Donating Members 5,077 Member For: 18y 4d Gender: Male Location: Ropes Crossing Posted 20/01/09 11:06 AM Share Posted 20/01/09 11:06 AM the relay is located in the engine bay right? if so, once it is removed should I turn the key in the ignition to 'on' for a few seconds Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/11/#findComment-806662 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 4m 27d Gender: Male Location: SW Sydney Posted 20/01/09 11:10 AM Share Posted 20/01/09 11:10 AM Yes its in the engine bay fuse box, once you've removed it, just crank the motor over, so hold it on the "Start" position for a few cranks - probably between 5-10 to get it all the way to the turbo Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/11/#findComment-806669 Share on other sites More sharing options...
