CJ_AK cj_ak Donating Members 5,077 Member For: 17y 6m 1d Gender: Male Location: Ropes Crossing Posted 20/01/09 11:14 AM Share Posted 20/01/09 11:14 AM your the man senna!!! thanks Link to comment Share on other sites More sharing options...
BFHOON Donating Members 1,932 Member For: 18y 9m 8d Gender: Male Location: nsw Posted 20/01/09 11:19 AM Share Posted 20/01/09 11:19 AM an easier way could be to hold your foot flat on the throttle, all the way to the floor and crank the motor over.it will not start with your foot flat on the gas. Link to comment Share on other sites More sharing options...
nifty Lost Member Donating Members 134 Member For: 16y 4m 27d Gender: Male Location: Perth Posted 20/01/09 11:25 AM Share Posted 20/01/09 11:25 AM you do already know that if you hold your foot to the floor on acc pedal, it wont actually fire, just roll over, to prime oil. When I bought my t about 4 months back, 60000km service found screen blocked and pushed its way thru the pipe into the turbo. lucky I got it in time before major damage. this was due to frauds lack of oil changes (only every 15000km) should be every 5000km. from what I now know, just do regular oil changes and it's not a problem. This is following Turbo tech's warranty advice, had to replace entire pipe & kit turbo. Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 17y 10m 25d Gender: Male Location: SW Sydney Posted 20/01/09 11:31 AM Share Posted 20/01/09 11:31 AM Well yes, you can do that too... Link to comment Share on other sites More sharing options...
Rushxr6t Member 10 Member For: 15y 11m 29d Gender: Male Location: Perth Posted 01/02/09 07:31 AM Share Posted 01/02/09 07:31 AM (edited) Hi Guys,Can anyone recommend someone in WA to fit a new filter, for a reasonable price of course,Cheers Edited 01/02/09 07:33 AM by Rushxr6t Link to comment Share on other sites More sharing options...
nifty Lost Member Donating Members 134 Member For: 16y 4m 27d Gender: Male Location: Perth Posted 05/02/09 09:54 PM Share Posted 05/02/09 09:54 PM Hi Guys,Can anyone recommend someone in WA to fit a new filter, for a reasonable price of course,Cheersbuy the screen from fraud, but do NOT let them fit it, then take it to turbo tech in belmont.cheers. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 3m 9d Gender: Male Location: Perth Posted 13/02/09 08:25 AM Author Share Posted 13/02/09 08:25 AM I think i may be getting good at this. I managed to replace the filter on my ute in 45mins today. I have two "special" 24mm spanners that are perfect for the task. Its actually very easy to access the fitting from the top if you have a Nizzer or similar plenum fitted.I paid $68 from ford for the fitting, interestingly the same part from Cov's was only $8 cheapers than genuine from the dealer. Next time it's due though i will be fitting the external earls filter i have. Link to comment Share on other sites More sharing options...
CJ_AK cj_ak Donating Members 5,077 Member For: 17y 6m 1d Gender: Male Location: Ropes Crossing Posted 10/03/09 03:09 AM Share Posted 10/03/09 03:09 AM I got myself one of those earl's inline filters and put it on the ute when we put the new turbo on it. Problem is though, I cant figure out how the old oil screen filter is no longer used?earl's braided hose has a ring on the end, the same as the stocker which the screen goes through. isnt those inline filters meant to replace the oil screen?? Link to comment Share on other sites More sharing options...
nifty Lost Member Donating Members 134 Member For: 16y 4m 27d Gender: Male Location: Perth Posted 10/03/09 08:26 AM Share Posted 10/03/09 08:26 AM just remove the factory screen completely, it's too much to ask for the oil to pass thru 2 filters. Link to comment Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 6m 12d Gender: Male Location: Earth Posted 10/03/09 12:10 PM Share Posted 10/03/09 12:10 PM How do you figure?The screen that is in the line to the turbo is after the oil filter.So it will only be filtering, if anything, particles that are picked up in the oil galleries, or anything that is 'shaved' off in normal operation.Plus, if you're still under warranty and you have an engine failure and it's discovered there isn't a filter in the fitting??Bye bye warranty, hello expensive replacement. Link to comment Share on other sites More sharing options...
