Turbo Oil Supply Screen Cleaning
Ralph Wiggum
  • Member For: 9y 8m 8d
Hey guys I'm doing this right now and got everything off minus the 24mm in the block. I read back a page and some one stated if you put a small screw driver through and it goes in more then a inch, the filter has been removed already. Well mine went in 2 inches, so I'm putting it all back together until someone else says no that's wrong and I'll do it again hahaha. Not that hard of a job from the top with the right tools
  • Member For: 17y 3d
The filter is a cylinder... A screw driver will always go through the middle
You got this far, just pull it out and have a look
Here is a pic
The mesh filter is around the inside of this fitting, it only filters the oil coming out the small holes in the middle
Edited by Wilko16
  • 1 month later...
Hey guys was hoping someone could point me in the right direction with how to get mine off to check, thought I may as well seeing as how my turbo has failed and I need to look at replacing it anyway so thought I'd take the filter out etc. while I had it all apart but mine doesn't look like the one in the photo? I tried taking a few pics here: I think the piece on the far left is from my oil pressure gauge? But even beside that it looks quite a bit different.
Any help would be great cheers!
  • Member For: 12y 9m 15d
You need to undo the fitting from the block, in your first photo. It's the one you can see connected to the line that runs upwards vertically. The filter is located inside this male to male adapter. All the rest of the stuff hanging off (oil pressure gauge sender, oil pressure switch all come off the fitting from the block which you need to take out. Just be careful getting it out though, that you don't over twist the banjo fitting and split the factory hard line...
Edited by demon1300
  • 3 weeks later...
  • 9 months later...
  • Puff
  • Member For: 9y 9m 26d
Undo the oil line.
First post of the thread and the first picture is what you want.
It's under the intake manifold.
Follow your oil line.
Read the thread for all the details you need.
