FiftyOne Bronze Donating Members 1,145 Member For: 11y 6m 12d Gender: Male Posted 07/03/15 09:02 PM Share Posted 07/03/15 09:02 PM Might have used one of them somewhere. Had info about all the other fittings though & how he went about it Link to comment Share on other sites More sharing options...
karlp2 Member 81 Member For: 11y 4m 28d Gender: Male Location: Auckland, New Zealand Posted 10/04/15 10:40 AM Share Posted 10/04/15 10:40 AM Rather than accessing from underneath you can remove the air filter box to access it from above. I've done it both ways and this way is quick to do and provides much better access. Hope this helps! Link to comment Share on other sites More sharing options...
Stray New Member 10 Member For: 9y 9m 28d Gender: Male Location: Wanneroo WA Posted 15/04/15 01:43 PM Share Posted 15/04/15 01:43 PM Looking at doing this on the weekend, if I'm just gonna get rid of the filter do I need to get new washers? Or just put it back together with the old ones? Link to comment Share on other sites More sharing options...
bamk2f6tornado Bronze Donating Members 777 Member For: 11y 1m 10d Gender: Male Location: Rockhampton Qld Posted 15/04/15 07:23 PM Share Posted 15/04/15 07:23 PM (edited) Should get new ones. They are pretty cheap from Ford. It's a job you will only want to do once so do it properly Edited 15/04/15 07:28 PM by bamk2f6tornado Link to comment Share on other sites More sharing options...
Stray New Member 10 Member For: 9y 9m 28d Gender: Male Location: Wanneroo WA Posted 15/04/15 09:27 PM Share Posted 15/04/15 09:27 PM Ok cheers Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 3m 21d Gender: Male Location: Perth Posted 16/04/15 12:22 AM Author Share Posted 16/04/15 12:22 AM Should get new ones. They are pretty cheap from Ford. It's a job you will only want to do once so do it properly^this...however in a pinch they can be reused and reannealed to soften them up. In the past when I have not had spares i've resurfaced them on a flat smooth piece of concrete then used the gas hob to anneal (soften) the copper again.But for all that effort and the risk of a leak...get new ones! Link to comment Share on other sites More sharing options...
f-wolf Member 897 Member For: 17y 8m 19d Gender: Male Location: ACT Posted 16/04/15 03:26 AM Share Posted 16/04/15 03:26 AM How to Anneal a Copper Washer Link to comment Share on other sites More sharing options...
GeGe6 Donating Members 1,978 Member For: 12y 6m 6d Gender: Male Location: Perth, SOR Posted 16/04/15 09:36 AM Share Posted 16/04/15 09:36 AM (edited) Been looking around for a thread that was started a little while back re the earls filter. Someone used some aeroflow fittings & P clamps to mount the filter to the front of the block instead of the side. It had a list of the bits he used. Can anyone point me in the right direction?I think from memory it's as simple as swapping the lines over.So the one that goes from block to filter, now goes from turbo to filter and vise versa.I found these clamps on EBay for cheap.I have purchased in -6 for a project, but do come in other sizes.Will give feed back when I receive them.Ebay item number 191545385932 Edited 16/04/15 09:37 AM by GeGe6 Link to comment Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 11y 6m 12d Gender: Male Posted 16/04/15 02:55 PM Share Posted 16/04/15 02:55 PM Cheers mate Link to comment Share on other sites More sharing options...
f-wolf Member 897 Member For: 17y 8m 19d Gender: Male Location: ACT Posted 18/04/15 02:15 AM Share Posted 18/04/15 02:15 AM This is what I used...http://s29.postimg.org/3saehpi5z/Filter_1.jpg Link to comment Share on other sites More sharing options...
