Force88 Donating Members 64 Member For: 14y 8m 3d Gender: Male Location: NQ Posted 03/06/13 06:59 AM Share Posted 03/06/13 06:59 AM doing this to my car today. got it apart, pulled the old filter out and went to re tighten the bolt that contained the old filter and cant get it to tighten up flush to the block. is it supposed to be able to be tightened so its flush? its not cross threaded. sits out about 2-3mm from the block and I cant get it to tighten any further than that Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/35/#findComment-1395334 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 6m 26d Gender: Male Location: Perth Posted 03/06/13 07:29 AM Author Share Posted 03/06/13 07:29 AM It's a tapered thread so I relies on the the taper to seal not a flush fit to the block so as long as you applied sealant to the threads you should be okay. Be careful not to over tighten the fittings as the blocks have been known to crack if the fitting is over tightened. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/35/#findComment-1395339 Share on other sites More sharing options...
Peteos13 Donating Members 307 Member For: 12y 14d Gender: Male Posted 03/06/13 07:40 AM Share Posted 03/06/13 07:40 AM I'm doing this on the weekend. Thanks for the how to write up Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/35/#findComment-1395341 Share on other sites More sharing options...
Force88 Donating Members 64 Member For: 14y 8m 3d Gender: Male Location: NQ Posted 04/06/13 06:15 AM Share Posted 04/06/13 06:15 AM cheers cheif wiggum you're the man! now back to building... Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/35/#findComment-1395559 Share on other sites More sharing options...
pac23 Member 103 Member For: 12y 11m 23d Gender: Male Location: Sydney Posted 04/10/13 01:39 AM Share Posted 04/10/13 01:39 AM I have been considering whether I do this or remove it completely.. How many people have done this and had problems? I have an fg ad my concern is the filter becoming brittle being that's it plastic as has been going through hot and cold cycles for the past 5 years. Being that my car runs full synthetic oil I can't see there being much sludge and metal should only be an issue on initial 1500kms. So correct me if I'm wrong but why is it even there? Because ford recommended oil is a mineral oil? Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/35/#findComment-1430305 Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 5m 30d Posted 04/10/13 02:04 AM Share Posted 04/10/13 02:04 AM Pretty sure ford only recommend mineral for run in, then semi-synthetic after that (someone correct me if I'm wrong). Some people don't do anything, some remove, and some change to an earls filter. Only times I've heard of turbo's going is by leaving it as is so you're going to get different opinions on what's best so hard to make your own judgement 1 Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/35/#findComment-1430311 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 18d Gender: Male Location: Adelaide Posted 04/10/13 02:06 AM Share Posted 04/10/13 02:06 AM Correct Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/35/#findComment-1430312 Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 8m 26d Gender: Male Location: Maryborough Qld Posted 04/10/13 02:34 AM Share Posted 04/10/13 02:34 AM Pretty sure ford only recommend mineral for run in, then semi-synthetic after that (someone correct me if I'm wrong). Some people don't do anything, some remove, and some change to an earls filter. Only times I've heard of turbo's going is by leaving it as is so you're going to get different opinions on what's best so hard to make your own judgementiuse full synthetic on my ba xr6t...have not had any dramas. Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/35/#findComment-1430318 Share on other sites More sharing options...
10SECN Member 516 Member For: 11y 11m 17d Gender: Male Location: west hoxton Posted 26/10/13 03:11 AM Share Posted 26/10/13 03:11 AM Just removed my screen. Took about 20 mins. Removed my air box. , 24mm sidchrome ring to crack both bolts and a tiny sunglass flat head to remove the screen. Back in and running with no leaks. Easy job Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/35/#findComment-1436025 Share on other sites More sharing options...
Z2TT Member 714 Member For: 12y 10m 23d Posted 16/11/13 09:28 AM Share Posted 16/11/13 09:28 AM I was wondering though would removing it cause issues or decrease life of turbo in long run as it was mentioned earlier in this thread that the oil pressure/flow going to the turbo might be too strong?Does the factory filter provide enough flow even when putting a big aftermarket turbo on? Link to comment https://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/page/35/#findComment-1440651 Share on other sites More sharing options...
