Turbo Oil Supply Screen Cleaning
Ralph Wiggum
  • It's not a MKI!
  • Member For: 16y 8m 15d
Well I was hoping sum one knows so I didn't have to pull it out for no reason
Yes there is a screen in the oil supply line to the turbo in the FG engines.
Have you not been through this thread? Plenty of reference to the FG screen.
  • Member For: 14y 7m 14d
  • Gender: Not Telling
Ok just a little more info. The oil filter screen is rated at 70 microns, the earls inline filter is rated at 85 microns and a good quality oil filter is rated at 25-30 microns. In conclusion I suggest that no filter is required after initial run in, and as there is an oil restrictor in the line located before the turbo, excessive flow is not an issue. Cheers
  • 1 month later...
  • Member For: 14y 1m 16d
I think I will be taking the filter out this weekend. I was thinking that if you REALLY wanted a filter in the system it might be an idea to use a remote mounted screw on replaceable filter like you often see with an oil cooler. Do they handle pressure or are they only for return oil?
  • Member For: 13y 5m 5d
I have the EARLS filter kit on on FG, im pretty happy with the kit, though I removed the banjo and what not from the block and fitted the earls kit in place, im unsure of where the stock screen is,
  • Member For: 14y 1m 25d
True, but if you had a full size filter it would never block up and it could be changed for $10 instead of cleaned.
The turbo's supply is after the engines oil filter as mentioned a heap of times, so you'd be best just removing the factory mesh in the turbo line.
