robbo k Member 414 Member For: 17y 1m 15d Location: Wollongong Posted 29/04/08 08:45 AM Share Posted 29/04/08 08:45 AM thanks mate I will look into it I will have to go see my machanic altho he is more into v8 he has turned out some xr6t one pushing some healthy numbers..... I think he uses some capa program.... Link to comment https://www.fordxr6turbo.com/forum/topic/32273-edit/page/8/#findComment-667503 Share on other sites More sharing options...
adzy Member 14 Member For: 17y 9m 15d Posted 28/07/08 07:51 PM Share Posted 28/07/08 07:51 PM What is the process for a custom tune on the dyno? I know about downloading the generic tunes into the stock ecu but how is the dyno tune done?Is the flash tuner left plugged in whilst on the dyno, or is it first plugged in to put the ecu into a custom tune mode ready fo the dyno allowing air/fuel ratios and timing to then be freely adjusted? Link to comment https://www.fordxr6turbo.com/forum/topic/32273-edit/page/8/#findComment-711628 Share on other sites More sharing options...
twisty1 Member 65 Member For: 16y 9m 3d Posted 19/08/08 01:35 AM Share Posted 19/08/08 01:35 AM This thread has cleared up a lot of misinformation. Link to comment https://www.fordxr6turbo.com/forum/topic/32273-edit/page/8/#findComment-720239 Share on other sites More sharing options...
Sprjenkins Member 52 Member For: 16y 10m 1d Gender: Male Location: Melbourne Posted 01/09/08 10:43 AM Share Posted 01/09/08 10:43 AM So what is the end result?What sort of RWKW can you expect after getting the edit. Link to comment https://www.fordxr6turbo.com/forum/topic/32273-edit/page/8/#findComment-726684 Share on other sites More sharing options...
XRPete Member 673 Member For: 17y 8m 12d Gender: Male Location: Here Posted 01/09/08 11:12 AM Share Posted 01/09/08 11:12 AM My car went from just under 200 rwkw to 240 rwkw. that's a good increase for just a tune. Link to comment https://www.fordxr6turbo.com/forum/topic/32273-edit/page/8/#findComment-726695 Share on other sites More sharing options...
Grug Member 1,318 Member For: 16y 9m 23d Posted 10/09/08 11:04 AM Share Posted 10/09/08 11:04 AM Does getting a custom tune increase fuel efficiency as well as power? At the moment I'm getting 13.5L/100KM and Im stock. Link to comment https://www.fordxr6turbo.com/forum/topic/32273-edit/page/8/#findComment-731521 Share on other sites More sharing options...
EZ2CME Formerly XR6NA Member 3,512 Member For: 19y 5m 22d Gender: Male Location: Brisbane Posted 10/09/08 11:20 AM Share Posted 10/09/08 11:20 AM If you can resist using the power all the time it should, but good luck with that. Link to comment https://www.fordxr6turbo.com/forum/topic/32273-edit/page/8/#findComment-731541 Share on other sites More sharing options...
BTK_007 Member 25 Member For: 16y 3m 9d Gender: Male Posted 25/02/09 12:57 PM Share Posted 25/02/09 12:57 PM Who are the best custom tuners round sydney? Link to comment https://www.fordxr6turbo.com/forum/topic/32273-edit/page/8/#findComment-831079 Share on other sites More sharing options...
brownhornet Donating Members 124 Member For: 16y 10m 3d Gender: Male Location: Perth Posted 26/07/09 04:42 AM Share Posted 26/07/09 04:42 AM I'm looking to get a custom tune but need a basic question answered first. I'm a bit confused with some of the terms: SCT, capa and Xcal. are they one and the same? are any models obsolete? Link to comment https://www.fordxr6turbo.com/forum/topic/32273-edit/page/8/#findComment-912109 Share on other sites More sharing options...
Trough Lolly Member 4,349 Member For: 20y 8m 14d Gender: Male Location: Mildura Posted 26/07/09 04:55 AM Share Posted 26/07/09 04:55 AM their all the same mate.... The company that makes the edit is called "SCT"... capa USED TO be the sole importer of the SCT flash tuner until they decided to be naughty...the flash tuners are now brought in Via Herrod motorsport.The SCT flash tuner started out as model "x-cal 1" then as time went on, model 2 & 3.... X-cal 1 is the best bang for buck if you just want a custom tune (they all hold 3 tunes + your factory tune), whereas x-cal 2 & 3 have live datalogging capabilities and also can read/clear ford error codes from the PCM. Link to comment https://www.fordxr6turbo.com/forum/topic/32273-edit/page/8/#findComment-912116 Share on other sites More sharing options...
