  • Team Grandpa Qualified
  • Member For: 20y 4m 25d
My BF's only 7500k's old - and yep - they still make em with the creaks built in.
It's called "luck of the draw". Simo.... check the various connections under your passengers seat number one, and then check up the top of the passengers footwell. There are a couple of cables that may be at fault. (Passenger side sounds can be a bit misleading - they may sound as though they are coming from high up in the dash, when in fact that is a reflected sound from lower / underneath.) I've nearly got mine sorted - apart from one that disappears as soon as you go look for it.
I'm with you - when need someone short to volunteer and crawl up inside to sort it. :spoton:
Guest newl
  • Guests
I must've drawn the lucky card. Mine is an October '04 build F6 and the only internal noises I hear are:
1) the radio
2) sun glasses rattling around in top drop down holder when they're not on my face
3) CD jewel cases in the console slopping around
4) radar detector vibrating on wind shield (I've got a fix for that..just need the motivation)
