  • Member For: 18y 11m 1d
[quote name='Goobz' date='Jan 23 2007, 04:38 PM']Nice Cooler! Are you planning on doing any full plumbing kits to replace the crossover in the near future that it might be worth hanging out for??
Chris :spoton:
[right][snapback]489262[/snapback][/right]
[/quote]
Yes, that and plenty of other products. Watch these forums.
Kevin
  • Replies 54
  • Member For: 19y 8m 22d
Is that little fitting to the right of the silicon hose a Boost map sensor relocation fitting ??
danny
  • Member For: 18y 9m 14d
Fitted one of these today everything fits perfect took about 1.5 hours on the driveway the car is getting tuned at autotech today will let you know the results
Nathan
  • Member For: 18y 11m 14d
[quote name='Headsex' date='Jan 25 2007, 01:31 PM']Is that little fitting to the right of the silicon hose a Boost map sensor relocation fitting ??
danny
[right][snapback]490096[/snapback][/right]
[/quote]
Might be a temp sensor bung for testing?
It is an extension for the boost/map sensor it runs a hose from where the factory under batery pipe runs to the cold side of the cooler plumbing
  • Member For: 19y 3m 24d
I assume this would be a huge improvement over the F6 cooler too. What sort of numbers can it support?
Looks good BTW
Guys
I wont be anywhere near a computer or the internet untill late Monday night...Ill answer all questions then.
Kevin
  • Member For: 18y 9m 13d
im running a stock motor and ecu map ect, will fitting this cooler affect how the car runs or will i need to get the car tuned to suit? im not looking for big numbers from my car more just for looks and to keep the charge air temps down while im towing ect.
cheers
Andrew
  • TEAM BA
  • Member For: 20y 4m 26d
Kevin, i'm in on the group buy... let me know how you want the deposit paid ect:)
[quote name='UTB05S' date='Jan 28 2007, 09:27 AM']im running a stock motor and ecu map ect, will fitting this cooler affect how the car runs or will i need to get the car tuned to suit?
[right][snapback]490926[/snapback][/right]
[/quote]
get the car tuned, a bigger cooler will play with the a/f ratios and cause it to lean out thats a bad thing mkay.. plus there isnt a point if your not going to put it to its full use.
so even though i plan on keeping the stock exaust and airbox she will still lean out? who is best to do an edit on it for this small mod and how much am i looking at roughly?
thanks in advance for any help guys.
Guest
This topic is now closed to further replies.
