New Interceptor Gauges!
Robit28
  • Replies 95
Posted Images
  • Member For: 19y 1m 1d
The main things that did not show that I would have liked are as follows:
Oil Pressure/Temp
Battery Voltage
HP
Although the gauges are still being tested so these may be available in the future I guess.
Things it does show that I like:
Boost / Vacuum
RPM
CAT Temp
Head Temp
Coolant Temp
Intake Air Temp
Ambient Temp
Transmission Temp
MAP Sensor kPa
Vehicle Speed
Engine Load
Throttle Position
Ignition Advance
Knock Retard
Injector Pulse Width
Short Fuel Trim
Long Fuel Trim
Fuel Level in %
Current Gear (Even when in 'D' on the auto)
Shift light works well and can be programmed on any parameter (eg, set to show when cooland goes over 95 degrees or when fuel level gets below 5% etc)
Also the 0-100 and quarter mile feature is excellent. The quarter mile was about .4 second out but good to get an idea. 0-100 very accurate.
Hope that helps!
Rob.
Edited by Robit28
  • Member For: 17y 7m 19d
Oil Pressure/Temp
Battery Voltage
HP
Boost / Vacuum
RPM
CAT Temp
Head Temp
Coolant Temp
Intake Air Temp
Ambient Temp
Transmission Temp
MAP Sensor kPa
Vehicle Speed
Engine Load
Throttle Position
Ignition Advance
Knock Retard
Short Fuel Trim
Long Fuel Trim
Fuel Level in %
Hope that helps!
Rob.
Rob,
so you get all those features in the 2 guages on your dash ?????????
if so im in for a group buy for sure......... they look great !
Ern
