  • Member For: 21y 17d
:spoton: Two of these and an autometer cobalt boost gauge in the tripod would be pretty f*ckin sweet.
I'd buy two without hesitation, as long as they can output in Celcius. Fahrenheit means sh*t all to me.
Edited by Spruce
  • Replies 95
Posted Images
  • 1 month later...
  • Member For: 19y 1m 15d
  86gav said:
Whats the reason behing only having 2? I would like 3 in a Tripod, would look a bit silly with 2 of these and 1 normal guage me thinks..
CHeers
Gav
Dual Interceptor Option: Two Interceptors can be purchased with a special splitter cable that allows both gauges to operate simultaneously
I think you will find that the cable only comes from the manufacturer so you can either run 1 guage or 2, they don't build a cable to cater for 3 guages me thinks :roflmbo:
Ohh and yes I am interested seeing as it will allow me to see 4 lines of data. Just all depends on what the interceptor unit can read from the Ford OBD-II port
Edited by Fat-Tony
  01txr said:
So is this dead or is there still hope in getting them.
Will these read AFR correctly.
No the displayed AFR will not be accurate as the gauge will draw the AFR reading from the cars narrow band 02 sensor, its well documented that narrow band sensors only read correct AFR's around stoichiometric ratio for petrol (1lambda/14.64:1 AFR) and its accuracy greatly degrades as you move further away from that AFR. So the only time it will be accurate is when your driving your car at cruise, light throttle application ect, which will have the ecu run the car in closed loop. If you want accuracy at any other point of the AFR range you will need to purchase a wide band 02 sensor and appropriate gauge. :roflmbo:
  • 2 weeks later...
  • 3 weeks later...
