koppers Member 119 Member For: 18y 5m 9d Posted 17/01/07 06:10 AM Share Posted 17/01/07 06:10 AM (edited) Hy guys, I am just wondering if any of you have experienced a speed cut in their Bf t at 180 km/h?It feels very similar to the limp mode caused from over-revving, we're just at a loss as to why it's occuring?The car has the 6 speed auto if that's any help, and runs 265 rwkw.Thanks in advance. Edited 17/01/07 06:11 AM by koppers Link to comment https://www.fordxr6turbo.com/forum/topic/31868-speed-cut/ Share on other sites More sharing options...
Ghia Member 191 Member For: 22y 5m 17d Gender: Male Location: Aus.Vic.Melb Posted 17/01/07 06:30 AM Share Posted 17/01/07 06:30 AM I'm assuming you have an Edit if you are running 265rwkw so wouldn't the tuner removed the Speed Limit? I thought they all pretty much removed the limit as a part of their normal process I was told mine was removed - allthough I haven't tested it out Link to comment https://www.fordxr6turbo.com/forum/topic/31868-speed-cut/#findComment-487284 Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 21y 8m 20d Gender: Male Location: Southern Highlands NSW Posted 17/01/07 06:50 AM Share Posted 17/01/07 06:50 AM These things are limited around 230+-. your tuner might have had a shocker Link to comment https://www.fordxr6turbo.com/forum/topic/31868-speed-cut/#findComment-487300 Share on other sites More sharing options...
TBO240 Member 628 Member For: 21y 9m 20d Gender: Male Location: Geelong Posted 17/01/07 07:16 AM Share Posted 17/01/07 07:16 AM I think the utes are speed limited to 180km. Link to comment https://www.fordxr6turbo.com/forum/topic/31868-speed-cut/#findComment-487312 Share on other sites More sharing options...
Paranormal Member 469 Member For: 21y 9m 1d Location: Brissy Posted 17/01/07 10:13 AM Share Posted 17/01/07 10:13 AM (edited) How much fuel did you have in your tank at the time, if less than 1/4 tank and you were flooring it as if running a 1/4 mile probably just fuel starvation, stock pump has a few limits, check threads on surge tanks and walbro / bosch fuel pump upgrades. Theres also a thread on modifying the pressure releif valve in the stock pump some where. Found this in my favorites old link but might explain things - Fuel pumps Edited 17/01/07 10:24 AM by Paranormal Link to comment https://www.fordxr6turbo.com/forum/topic/31868-speed-cut/#findComment-487395 Share on other sites More sharing options...
SCRIBR Yaris member Member 4,486 Member For: 18y 11m 4d Gender: Male Posted 17/01/07 10:22 AM Share Posted 17/01/07 10:22 AM damn utes! Link to comment https://www.fordxr6turbo.com/forum/topic/31868-speed-cut/#findComment-487400 Share on other sites More sharing options...
koppers Member 119 Member For: 18y 5m 9d Posted 17/01/07 12:58 PM Author Share Posted 17/01/07 12:58 PM Thanks for the tips guys. he fuel level at the time was rather low from memory, so next time we go back to the same private test track, the run will be completed with more fuel on board.It will also be a good opportunity to test the ute max 180km/h theory.With respect to the tuner, and him missing it, we have been in touch with him oday, and h himself is at a loss to the situation. Only guessing at the fuel tank levels himself.Thanks for the advice, will come back with more news later. Link to comment https://www.fordxr6turbo.com/forum/topic/31868-speed-cut/#findComment-487454 Share on other sites More sharing options...
BAturb Member 521 Member For: 20y 6m 11d Gender: Male Location: Adelaide Posted 17/01/07 06:41 PM Share Posted 17/01/07 06:41 PM I have a ute and have reached the speed limiter a couple of times at 235kmph Link to comment https://www.fordxr6turbo.com/forum/topic/31868-speed-cut/#findComment-487466 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 1m Gender: Male Location: Brisbane Posted 17/01/07 10:28 PM Share Posted 17/01/07 10:28 PM TBO240 said: I think the utes are speed limited to 180km.←That was only the NA's - different tailshaft or something. Link to comment https://www.fordxr6turbo.com/forum/topic/31868-speed-cut/#findComment-487489 Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 21y 8m 20d Gender: Male Location: Southern Highlands NSW Posted 17/01/07 10:48 PM Share Posted 17/01/07 10:48 PM tab said: TBO240 said: I think the utes are speed limited to 180km.←That was only the NA's - different tailshaft or something. ←Think the Na's might be alloy. Looked at one the other day Link to comment https://www.fordxr6turbo.com/forum/topic/31868-speed-cut/#findComment-487504 Share on other sites More sharing options...
