Mods To A Bf
PSIFRK
  • Member For: 18y 14d
I have a BF MK1 6 spd with no engine mods (yet) but I wanted help with what I should do first and what kind of order I need to go in I'm looking for around 330-350Kw (engine) can anyone help at all, thanks.
  • Member For: 19y 7m
there are ALOT of threads on this,
but to summarise: edit, cat, cooler, injectors pump should get you there..
you might need valve springs but I think the bf's have better ones than the ba im pretty sure..
if its a manual you may also need a new clutch
do a search mate!
thanks heaps guys, I've been looking at the CAPA stage 2 kit cause a mate of mine is going to do my exhaust for me 3" from turbo to cat then twin 2.5 split at the back for quad tips. hopefully it's sounds good and after the mods go a little harder :sick:
  • 2 weeks later...
  • Member For: 18y 9m 30d
for the bf all u need is injectors and an edit to start with.
as I have seen you should get 250 rwkw with a tune only but injectors will allow more boost to be used around 270rwkw then the clutch will give up with more than that so then u need to spend more :spoton:
