  • Member For: 18y 6m 24d
Installed a wog cooler with a little help from the gf, once the holes were drilled...then another hole drilled in the bracket so that the hole was in the right place (bracket completely wrong) I had it tuned by C&V again......
Before the retune 253rwkw (injectors maxed out), after retune 266rwkw. THe car is a 6 speed manual BA Mk2 turbo. Must say that the difference is huge especially in the heat. The hot weather doe not bother the car anymore, you can feel a slight drop in power when it's really hot but not like with the stock intercooler.
I would recommend an intercooler upgrade for anyone, whichever brand you want to use go ahead. Obviously some have advantages over others.....but I was happy with the direct bolt up (after some modification!) wog cooler as it was relatively easy to fit. I was looking at the APS kit but the expense was not worth it for my level of modification in the end.
  • KILL,KILL,KILL,DIE,DIE,DIE,
  • Member For: 19y 20d
  bencat said:
Ok, been wanting to ask this for ages, wtf is a Wog cooler ? Yes yes, it's an intercooler I know, but is Wog the brand ?
The ''wog cooler'' is really autotechnic MONZA intercooler there was a tuner on this site who's nick name was ''the wog'' and and he used to supply them to a lot of members hence the name the ''wog cooler''.
:spoton:
  • Member For: 19y 3m 21d
God I wish I had a girlfriend like that... :stirthepot:
  • Faster than any BTA,XTC,Autotech, Nizpro and Tunehouse car
  • Member For: 21y 11m 2d
How many holes did you have to drill before she helped you :stupid:
I hope you used protection when you were drilling :pooh:
