jetute Donating Members 4,553 Member For: 21y 3m Gender: Male Location: brisbane Posted 08/01/07 10:18 AM Share Posted 08/01/07 10:18 AM (edited) I have also pulled at least 50 runs on that dyno and can tell you that it is accurate... and my results are backed by 2 other dynos! The only way the figure may be wrong is if someone has played with the settings Edited 08/01/07 10:18 AM by jetute Link to comment https://www.fordxr6turbo.com/forum/topic/31663-first-time-on-dyno/page/2/#findComment-484518 Share on other sites More sharing options...
FPV TRANNY Im the one and only Donating Members 3,557 Member For: 20y 3m 24d Gender: Male Location: In my house Posted 08/01/07 10:20 AM Share Posted 08/01/07 10:20 AM Paul@eliteauto said: Why is the intake temperature so high. On an xrt you miight het up to 5 degrees more but not that much.The higher the intake temp the higher the kw reading.Just seems strange to me.←It was a stinking hot day here today and especially at wacol.You could be right paul.It does seem high for a stocky Link to comment https://www.fordxr6turbo.com/forum/topic/31663-first-time-on-dyno/page/2/#findComment-484519 Share on other sites More sharing options...
Tex Member 56 Member For: 20y 11m 8d Location: Brisbane Posted 08/01/07 10:23 AM Author Share Posted 08/01/07 10:23 AM Paul@eliteauto said: Why is the intake temperature so high. On an xrt you miight het up to 5 degrees more but not that much.The higher the intake temp the higher the kw reading.Just seems strange to me.←I am not sure about the intake temp I know you can get high readings if the sensor is put near something hot. As far as I know the sensor was put in the CAI. Link to comment https://www.fordxr6turbo.com/forum/topic/31663-first-time-on-dyno/page/2/#findComment-484520 Share on other sites More sharing options...
BALLBREAKER Member 427 Member For: 19y 10m 12d Gender: Male Posted 08/01/07 10:25 AM Share Posted 08/01/07 10:25 AM Tex said: The eye brows did go up. The car felt strong out of the box. I had a BAT with an Xede and it only pulled 233 with the best tune they could give which was done by Chiptorque.←That what I mean mate ,but any way with a cooler & a capper flasher custom tuned,over 250 rwkw NO PROB at all.CHEERS BB Link to comment https://www.fordxr6turbo.com/forum/topic/31663-first-time-on-dyno/page/2/#findComment-484521 Share on other sites More sharing options...
Tex Member 56 Member For: 20y 11m 8d Location: Brisbane Posted 08/01/07 10:28 AM Author Share Posted 08/01/07 10:28 AM I wouldn't normally have posted a first dyno slip but because it was so high I though the discussions might be interesting. As I said I am putting it back on tomorrow to see what difference a cooler makes. I will pay particular attention to the intake temp. Perhaps we will get a realistic reading. I will post the results. Link to comment https://www.fordxr6turbo.com/forum/topic/31663-first-time-on-dyno/page/2/#findComment-484523 Share on other sites More sharing options...
Paul@eliteauto Member 843 Member For: 18y 8m Gender: Male Location: Brisbane Posted 08/01/07 10:29 AM Share Posted 08/01/07 10:29 AM FPV TRANNY said: It was a stinking hot day here today and especially at wacol.You could be right paul.It does seem high for a stocky←yep it was hot at Archerfield too.We tuned a Bf auto today and got 265 rwkw with standard cooler on 10 psi. Link to comment https://www.fordxr6turbo.com/forum/topic/31663-first-time-on-dyno/page/2/#findComment-484524 Share on other sites More sharing options...
ROLMDL role model Member 1,111 Member For: 19y 1m 21d Gender: Male Location: Melbourne,S.E Posted 08/01/07 10:30 AM Share Posted 08/01/07 10:30 AM Tex said: I wouldn't normally have posted a first dyno slip but because it was so high I though the discussions might be interesting. As I said I am putting it back on tomorrow to see what difference a cooler makes. I will pay particular attention to the intake temp. Perhaps we will get a realistic reading. I will post the results.←fitting the bigger cooler will help alot and should get nice inprovementare you fitting the capa boxs aswell? Link to comment https://www.fordxr6turbo.com/forum/topic/31663-first-time-on-dyno/page/2/#findComment-484526 Share on other sites More sharing options...
FPV TRANNY Im the one and only Donating Members 3,557 Member For: 20y 3m 24d Gender: Male Location: In my house Posted 08/01/07 10:31 AM Share Posted 08/01/07 10:31 AM Paul,I have a mate with an XR6T on the gold coast that will require a custom tune.I will send him your way. Link to comment https://www.fordxr6turbo.com/forum/topic/31663-first-time-on-dyno/page/2/#findComment-484528 Share on other sites More sharing options...
Paul@eliteauto Member 843 Member For: 18y 8m Gender: Male Location: Brisbane Posted 08/01/07 10:33 AM Share Posted 08/01/07 10:33 AM Fitting a bigger cooler lost me power when I fitted it to my car.Because of the larger volume of air required to fill it I lost boost.I did recover and gain power after retune. Link to comment https://www.fordxr6turbo.com/forum/topic/31663-first-time-on-dyno/page/2/#findComment-484531 Share on other sites More sharing options...
Tex Member 56 Member For: 20y 11m 8d Location: Brisbane Posted 08/01/07 10:33 AM Author Share Posted 08/01/07 10:33 AM Black ThundeR said: Tex said: I wouldn't normally have posted a first dyno slip but because it was so high I though the discussions might be interesting. As I said I am putting it back on tomorrow to see what difference a cooler makes. I will pay particular attention to the intake temp. Perhaps we will get a realistic reading. I will post the results.←fitting the bigger cooler will help alot and should get nice inprovementare you fitting the capa boxs aswell?←I have an Xcal 2 on the way Link to comment https://www.fordxr6turbo.com/forum/topic/31663-first-time-on-dyno/page/2/#findComment-484532 Share on other sites More sharing options...
