Rab WOT? Moderating Team 10,981 Member For: 12y 2m 21d Gender: Male Location: Frankston, 3199 Posted 07/11/14 09:54 AM Share Posted 07/11/14 09:54 AM A quick read through the first bits of my thread should give you a bit of info as to what Mick did to get mine up and over the 300 mark.With regards to the petrol injectors - my take on it is that you need to get the injectors flow to match the gas flow, so the car is able to stay within it's parameters and get the fuel it's expecting.Mick did have to do a bit of magic to get the gas to flow at a higher rate than what the system will do stock - in my case he got it up to around the 42lb injectors. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/31658-xr6t-with-injected-lpg/page/15/#findComment-1510931 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 5m 26d Gender: Male Location: Brisbane Posted 07/11/14 10:34 AM Share Posted 07/11/14 10:34 AM Cheers Rab will check it out Link to comment https://www.fordxr6turbo.com/forum/topic/31658-xr6t-with-injected-lpg/page/15/#findComment-1510942 Share on other sites More sharing options...
