Underdrive Pulleys
gt-p
  • Member For: 12y 5m 22d
Be careful when looking at Dyno Comparisons, if there done on different days they might not be totally accurate.
I'd say anything that reduces the rotating mass will help but you need to ask a few members who have actually done the
upgrade on their personal cars and ask them.
  • Member For: 11y 10m 2d
Okay guys, thanks for the help and opinions and stuff, but this is for the motor, will get to lightness later.
And Z2TT, man I totally agree with you, but like.. on a N/A I6.. Yeah maybe couple of different results, but 9.5rwkw I dont think is just a 'good day'..
Like I said.. on a N/a 6 anyway. But a turbo'd Vehecle, I'd agree.
Edited by Bazza96
  • Menace
  • Member For: 13y 6m 27d
FYI (doin a wiki haha)
Posted Image
1. (Blue curve) Factory wheels: 20”x9.0” with Pirelli 275/40-20 tires weighing 68 lbs combined per rear wheel. – Max hp: 371 hp, Max Torque: 375 ftlbs - (Baseline)
2. (Red curve) Aftermarket wheels: 20”x9.0” with Pirelli 275/40-20 tires weighing 72 lbs combined per rear wheel – Max hp: 369 hp, Max Torque: 373 ftlbs - (A [-] loss of 2 hp and 2 ftlbs)
3. (Green curve) HRE wheels: 20”x11.0” with Nitto 315/35-20 tires weighing 60 lbs combined per rear wheel – Max hp: 380hp, Max Torque: 384 ftlbs - (A [+] gain of 8 hp and 9 ftlbs and that is running a 2” wider wheel/tire combo)
Conclusion:
The engine obviously still cranks out the same amount of hp and torque, the lighter HREs simply waste less of it before it gets to the ground. Also interesting to note is that the gains are not just peak gains, but gains across the entire rev range. If they had done a braking test, we would have seen similar results as the rotational inertia effects also have a significant effect on how much energy is used to stop the wheel/tire combo vs. stopping the car. We talk about these effects all the time and focus on designing lightweight wheels with low rotational inertia, but it isn’t every day that you get to see real hard data showing the true effects.
