ratter Member 6,793 Member For: 19y 18d Gender: Male Location: @ my laptop Posted 08/01/10 11:44 AM Share Posted 08/01/10 11:44 AM My old car (boss 290) made an average of 7 rwkw gain at the rears. Link to comment https://www.fordxr6turbo.com/forum/topic/31618-underdrive-pulleys/page/17/#findComment-969205 Share on other sites More sharing options...
Ryan C Member 9 Member For: 15y 9m 4d Gender: Male Location: Sunny Coast, QLD Posted 08/01/10 10:21 PM Share Posted 08/01/10 10:21 PM that's sweet, pretty good for just a 40 min bolt on job. Any idea what I should be looking at next? Thinking of a tune at the moment. Have heard mixed reports on cams... Link to comment https://www.fordxr6turbo.com/forum/topic/31618-underdrive-pulleys/page/17/#findComment-969244 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 18d Gender: Male Location: @ my laptop Posted 09/01/10 12:43 AM Share Posted 09/01/10 12:43 AM cams will work but most people forget that changing cams changes air flow characteristics, the head should really be ported and valves changed to match the flow of the new cams. Cams normally work by moving the power range higher up in the rpm area so normally some bottom end can be lost and the car may actually be slower unless diff gears and convertor (if auto)are changed to match the rpm range.Most bolt in cams will not generally result in much of a gain, but sometimes lots of little things can result in a great gain.Tuning should be done to get the best results of headers etc. Link to comment https://www.fordxr6turbo.com/forum/topic/31618-underdrive-pulleys/page/17/#findComment-969268 Share on other sites More sharing options...
Ryan C Member 9 Member For: 15y 9m 4d Gender: Male Location: Sunny Coast, QLD Posted 09/01/10 10:05 PM Share Posted 09/01/10 10:05 PM Great thanks mate, that's some food for thought. Hmmmmmm. Link to comment https://www.fordxr6turbo.com/forum/topic/31618-underdrive-pulleys/page/17/#findComment-969446 Share on other sites More sharing options...
Stink Senior Moron Donating Members 1,059 Member For: 16y 1m 22d Gender: Male Location: Sunshine Coast..... somewhere Posted 10/01/10 06:19 AM Share Posted 10/01/10 06:19 AM Did you notice a difference in your steering at all? Link to comment https://www.fordxr6turbo.com/forum/topic/31618-underdrive-pulleys/page/17/#findComment-969571 Share on other sites More sharing options...
Ryan C Member 9 Member For: 15y 9m 4d Gender: Male Location: Sunny Coast, QLD Posted 10/01/10 09:15 AM Share Posted 10/01/10 09:15 AM I noticed just once when I was parking it at the shopping centre seemed the power steeering dropped out for a second but then it was fine. However it has done that to me before with the stock balancer.... But time will tell as its only been 3 days of having it. Link to comment https://www.fordxr6turbo.com/forum/topic/31618-underdrive-pulleys/page/17/#findComment-969607 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 18d Gender: Male Location: @ my laptop Posted 10/01/10 09:23 AM Share Posted 10/01/10 09:23 AM if you were concerned about p/steer etc, ask your tuner to bump up the idle by approx 150 rpm, problem solved (if a problem existed) Link to comment https://www.fordxr6turbo.com/forum/topic/31618-underdrive-pulleys/page/17/#findComment-969610 Share on other sites More sharing options...
Ryan C Member 9 Member For: 15y 9m 4d Gender: Male Location: Sunny Coast, QLD Posted 11/01/10 07:45 AM Share Posted 11/01/10 07:45 AM Are you able to bump up the idle yourself using the Ford x3 Flash Tuner or does the flash tuner require a computer program to do this then reload the tune onto the car? Link to comment https://www.fordxr6turbo.com/forum/topic/31618-underdrive-pulleys/page/17/#findComment-969835 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 18d Gender: Male Location: @ my laptop Posted 11/01/10 08:18 AM Share Posted 11/01/10 08:18 AM if you have an X3 and it is enabled you can change your idle speed Link to comment https://www.fordxr6turbo.com/forum/topic/31618-underdrive-pulleys/page/17/#findComment-969852 Share on other sites More sharing options...
boost-kid Member 80 Member For: 16y 9m 20d Posted 11/01/10 09:22 AM Share Posted 11/01/10 09:22 AM I too was thinking about a cam, but from ratters comment it has sort of put me off now.so what would be a better option either 1 or the other WITH a tune in terms of power, a cam or diff gears?im not sure but my understanding is diff gears give better power down low?what sort of ratio would be good? and what would the difference be compared to standard?? Link to comment https://www.fordxr6turbo.com/forum/topic/31618-underdrive-pulleys/page/17/#findComment-969868 Share on other sites More sharing options...
