  • Replies 93
Posted Images
  • Yaris member
  • Member For: 18y 10m 18d
excellent work!
looks great in the bay!
obviously works a treat too!
well done and may you get much enjoyment out of it!
good luck with that 11.5 :idunno:
Edited by SCRIBR
  • - Track Bound EVO III -
  • Member For: 20y 4m 24d
  tab said:
That's awesome - so are you still going back to the drawing board or are you content with this one?
Just the shape tabby. Gotta find out for myself if a square box has any negligible effect over a nice rounded one...
  SCRIBR said:
excellent work!
good luck with that 11.5  :bum:
That's the key thing I think..
The enjoyment that comes from turning a piece of sheet alloy into a working piece in an engine bay, with only my own theory base behind it....
A few of the guys that have seen it are either amazed I made it from scratch, or think I'm an engineer of some kind :pinch:
  DBOSS said:
Good result Ben well done mate :fool:  :idunno:
Don't worry DBIATCH, I'm chasing down your 11.5's :spit:
Cheers.
  Adrian6T said:
Great work Ben. Looks the goods too.
Cheers Adrian, are you coming to the next track day?? March??
  • T.P.I.S.
  • Member For: 20y 5m 6d
Buy the looks of my tyresim not. I got to get a few more k's out of these. You should have fun.
Volume is not engine capacity.. It's something I thought would work.. Actually, I made it first, then measured it!! But I had an idea of where I wanted to go with it..
There is no real set theory on the volume, ranging from = to engine capacity to double engine capacity..
  • Member For: 19y 3d
Ok, let me re-phrase:
Your engine has a bore x stroke x no cylinders to give a certain displacement. In our case, close to 4liters.
So, how much liquid can your plenum keep?
Anyway, depending application, plenum size do vary, you are correct, one of the great engine builders of all time, Smokey Yunick from the USA reckons for turbo applications the plenum volume should be close to total displacement of engine.
This yields very good throttle response, and good reservoir capacity on sudden full-throttle acceleration, giving turbo decent time to spool up before a significant drop in charge pressure occurs.
Anyway the close to ideal solution for road-race applications, final application will determine plenum chamber volume in turbo applications. Racing on twisty roadways with lots of on/off type driving will benefit more from a smaller relative plenum, and for constant high-speed (read rpm) a larger plenum will do a lot to dampen oscillations in intake pressure, and thus powerlevels.
So yes, just my titbit, just wondered out of sake of curiosity what your volume was, since it made a significant difference in power levels, probably due to lower restriction, thus higher charge pressure realized at the ports, and you mentioned better throttle response, ascribed to the smaller plenum volume, ridding your intake system of the long lengths of piping.
Most likely you will feel an immediate response of the line, big improvement, and then a quicker build of your torque-curve due to smaller volume to pressurize.
So, average power/torque should have increased?
Thanx for the feedback anyway, it is appreciated.
Best regards,
MrBean.
  • Member For: 22y 1m 9d
Good on ya for doing that back to back testing. You said you used 10mm base and 6mm for the sides. There is another guy on one of the ford forums who has made a few like yours and I think he uses 8mm for the base and 4mm for the sides and that he has not had any problems. Just might save you a bit of work using thinner materials. Ally is not cheap either.
Have you got a pic on the underside?
Cheers.. I have overlayed the graphs, so I'll have a 3 run comparison to study when all my 'testing' is complete.
Underside I did differently, so it's like the winged keel I suppose.. So no pikkies :w00t2:
