  • Member For: 18y 3m 16d
You have probably pulled the hose iff the actuator so there is no boost signal to act on the diaphragm. Im assuming you car has been tuned... As I would think that the factory tune would have clipped the o/boost before 30psi.
  • Member For: 13y 10m 12d
Or you plugged the hose into the wrong outlet! I have done this several times! Boosted over 30psi :/ make sure the hose is in the correct outlet on the solineiod as one is a breather!
  • Member For: 16y 7m 1d
Lol sounds like you lubed things up a little too good. Check the hose that connects to the front housing.
Edited by Paulie2256
  • The Toxic Rocket
  • Member For: 15y 1m 29d
I think I lubed it up too well :/
Stupid Henz saying lube the sh*t outta it haha
so what now? dry it out?
hoses are on correctly
To much wd40 surely wouldn't cause overboost!
Make sure the hoses are on and on the correct spot. Chuck some pics up of the solineiod and your turbo front!
Edited by Kosij
  • Member For: 13y 10m 28d
Maybe when u got it tuned it was pretty gummed up and now that uve cleaned it its not controlling boost like it was when it was tuned.. Either that or Uve split a hose or its now leaking... Or its shagged now or not plugged in properly.
Edited by welshy_89
  • Member For: 17y 6m 29d
Man this is the 50% bonus boost thread not 500% :(
  • The Toxic Rocket
I'll pull it out again this arvo.
I have the actuator line going to the side outlet and the turbo nipple line going to the top of the solenoid.
Feels great to drive now but really gotta watch the gauge and not go over 15psi :/
Edited by Trent0
  • Will do skids for food
  • Member For: 13y 7m 18d
Tried this today on my mkII FG and noted the solenoid appears to be in a slightly different location to the mkI that makes it a bit easier to get to.
But being lazy, I just undid the hose from the turbo and squirted some RP7 in there.
It took me longer to get a photo of it than to actually do the job !
I decided to do this as I just got a new nizpro cooler and I think the bigger volume might have affected the time it took to build boost, so I thought this might help a bit and I'm pretty sure it did.
Edited by Boganspeed
  • 2 months later...
  • Member For: 12y 11m
Hi, I used wd40 to lube the boost solenoid....f*ck me makes a world of difference! funnie how I only did it about 5000k's ago...
Im just wondering how common are they to fail or get "tired" over time? would it be best for me to replace it? if so what the part number for it?
is it better to take the solinoid off completely and clen it out with carb cleaner then lube it with wd40??
also is there a spring on the wast gate? ive herd these can get weak over time aswell??
