discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 4m 21d Gender: Male Location: Probably above atmospheric pressure Posted 08/09/12 01:40 AM Share Posted 08/09/12 01:40 AM Resulting in gooey substances? Link to comment https://www.fordxr6turbo.com/forum/topic/31329-boost-solenoid-maintenance/page/53/#findComment-1291761 Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 7m 26d Gender: Male Location: Zombie Birdhouse Posted 08/09/12 02:10 AM Share Posted 08/09/12 02:10 AM Might treat me self to a six pack of "throttle bottle" Link to comment https://www.fordxr6turbo.com/forum/topic/31329-boost-solenoid-maintenance/page/53/#findComment-1291773 Share on other sites More sharing options...
crazyxa Member 84 Member For: 18y 1m 2d Posted 08/09/12 12:38 PM Share Posted 08/09/12 12:38 PM Not knowing older models but on the FG this is very easy to do. Just like others who have posted I just used the vacuum hose on the compressor housing to the solenoid. Step 1. Remove intercooler pipe from turbo compressor to intercooler. This just provides for easy access to the vacuum hose.Step 2. Then disconnect the vac hose on the compressor housing spray WD40 or Throttle bottle cleaner into the hose. Let it sit and foam and then repeat a couple of time for good measure. Then reconnect it.So don't have to stuff around removing brackets batteries etc. Link to comment https://www.fordxr6turbo.com/forum/topic/31329-boost-solenoid-maintenance/page/53/#findComment-1291975 Share on other sites More sharing options...
brettenator Member 66 Member For: 14y 3m 12d Gender: Male Posted 10/09/12 02:47 PM Share Posted 10/09/12 02:47 PM On 09/05/2012 at 2:23 AM, Shyfrd said: Same I haven't heard a bad story come out of pit lane. Everyone's been happy with their car that I know that's been thereInteresting that they advise against doing this 'mod'. Link to comment https://www.fordxr6turbo.com/forum/topic/31329-boost-solenoid-maintenance/page/53/#findComment-1292885 Share on other sites More sharing options...
lildavo Member 12 Member For: 12y 7m 20d Gender: Male Posted 12/09/12 08:22 AM Share Posted 12/09/12 08:22 AM I found my ba had no boost solarnoid hooked up vac line went straight from turbo to waste gate. Got a new one but no idea which hose go where on the solarnoid ford only think hose fromWaste gate goes near spot with the plug and turbo vac line is the right angle one???? Link to comment https://www.fordxr6turbo.com/forum/topic/31329-boost-solenoid-maintenance/page/53/#findComment-1293834 Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 8m 18d Gender: Male Posted 12/09/12 08:44 AM Share Posted 12/09/12 08:44 AM Hose from compressor housing to top (electrical connector) side of solenoid, hose from wastegate to bottom of solenoid Link to comment https://www.fordxr6turbo.com/forum/topic/31329-boost-solenoid-maintenance/page/53/#findComment-1293841 Share on other sites More sharing options...
lildavo Member 12 Member For: 12y 7m 20d Gender: Male Posted 12/09/12 11:31 AM Share Posted 12/09/12 11:31 AM Thanks mate. Throught be case didnt want to mix them up. I know the one with the cap isnt used Link to comment https://www.fordxr6turbo.com/forum/topic/31329-boost-solenoid-maintenance/page/53/#findComment-1293906 Share on other sites More sharing options...
PSI O6T Donating Members 440 Member For: 12y 7m 2d Gender: Male Location: sydney Posted 06/10/12 09:57 PM Share Posted 06/10/12 09:57 PM (edited) ok bathurst morning, had a bit of time as I got up early so decided to do the boost solenoid thingy.left battery in car and took off intercooler pipe,I also moved a few things for a clearer path to it as its pretty tucked away.undone the bolt(10mm) with long extension 1/4 drive I just clipped the actual solenoid out of the metal bracket and then unplugged the 2 hoses and the push on electrical connection.http://http://i303.photobucket.com/albums/nn134/tresurehunt/2ED11CDA-0409-46BF-ADFA-2269A5DAF56E-3808-0000043D799E3BA2.jpg"]http://http://just hit everything with WD-40 cleaned solenoid and sprayed down hoses and gave them a good soak ,just put everything back together, hardest part was the bottom intercooler clamp as it was one of those spring type,prob should just replace it to the screw type.ok I let the car idle for about 3-5 mins jumped in and took it for a spin.car is completely stock apart from air box mod and k&n panel filter, didn't notice much difference down low but mid range was a bit stronger ,after a few hits it suffered from the stock cooler so that was that . ill give it a go later on, over all a pretty easy job allow yourself up to 40 min, if your not mechanically minded , next time I do it wont take more than 10-15 min as I left off the bracket and just cable tied it to a hose. Edited 06/10/12 09:59 PM by tresurehunt 1 Link to comment https://www.fordxr6turbo.com/forum/topic/31329-boost-solenoid-maintenance/page/53/#findComment-1305808 Share on other sites More sharing options...
Pesaveng88 Member 23 Member For: 12y 10m 17d Posted 13/10/12 05:55 PM Share Posted 13/10/12 05:55 PM Searched through the pages but don't think if anyone said the size of the hose clamp (screw type) needed? If you go to supercheapauto website and type hose clamp, has a few pages of them. Any help is appreciated. Link to comment https://www.fordxr6turbo.com/forum/topic/31329-boost-solenoid-maintenance/page/53/#findComment-1308949 Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 13y 11m 24d Gender: Male Location: Sydney Posted 13/10/12 05:57 PM Share Posted 13/10/12 05:57 PM pretty sure its a 3/8" hose well near enough anyway. Link to comment https://www.fordxr6turbo.com/forum/topic/31329-boost-solenoid-maintenance/page/53/#findComment-1308950 Share on other sites More sharing options...
