  • Member For: 18y 8m 25d
I did this to my standard xr6t and pick up 20rwkw
  • Member For: 15y 5m 4d
I think the TB cleaning is more about the laminar flow of air through it than the sticking side of it.
  • Member For: 17y 6m 28d
  • New Member
  • Member For: 14y 7m 13d
I don't think it would be laminar flow, more like reduced pressure drop due to the rough walls through the throttle body. I cant see the airflow being particularly laminar after going through the turbo, the intercooler and all the piping. Not to mention going past the butterfly of the throttle body itself if you're not at WOT...
hmm, now that I think about it, it could be a build up restricting airflow when the butterfly is mostly closed which would explain the issues at idle I guess.
Edited by Mini Hulk
  • 2 weeks later...
  • Here since the start...
  • Member For: 22y 1m 27d
No. It will say code as the system is checked for a few seconds. After that it will function as normal.
  • 1 month later...
  • Special needs member.
  • Bronze Donating Members
  • Member For: 14y 9m 16d
Took a shortcut doing this on mine the other day and just took the hose off the actuator and filled it with WD40. Let it soak for a couple minutes then drained out the excess. Noticed heaps off difference with boost coming on earlier and easier to get to then the solanoid. Put a hose clamp on for a safe measure to stop it slipping off the actuator.
Edited by BigAl's04
