typhoon_freak Cryptic Clothing Company Donating Members 4,556 Member For: 16y 7m 7d Gender: Male Location: Brisvages, Capalaba Posted 07/04/09 08:36 AM Share Posted 07/04/09 08:36 AM shutup u.. Link to comment Share on other sites More sharing options...
MYBAXRT Member 158 Member For: 15y 11m 12d Gender: Male Location: nowra Posted 24/04/09 10:49 AM Share Posted 24/04/09 10:49 AM I just got the capa flash tuner but when I put the tune on I started to get a very fast tapping sound coing from around the fuse box under the hood. and some one said from here that its the boost solanoid that's sh*t its self.so I have 2 questions1. where is the boost solanoid and what does it look like ( pics would be great if anyone has any).2. how much it costs for the part and to get it fitted (can I do it my self?)thanks robert Link to comment Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 21y 5m 12d Gender: Male Location: Southern Highlands NSW Posted 24/04/09 10:53 AM Share Posted 24/04/09 10:53 AM There is a boost solenoid thread. Try this before you change itClick here Link to comment Share on other sites More sharing options...
Superdan Well-Hard Bangin' Member Member 3,422 Member For: 17y 5m 28d Gender: Male Location: Perff, WA Posted 24/04/09 11:00 AM Share Posted 24/04/09 11:00 AM Have another read of the other thread you started Robert, they were not saying it is the solenoid that is the problem. seventytwo suggested that it may be something in the tune that is affecting the boost solenoid. Flash the car back to the stock tune and have a listen to see if you still get the same sound, and let us know Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 9m 22d Gender: Male Location: Victoria Posted 24/04/09 11:05 AM Share Posted 24/04/09 11:05 AM Crikey!The ticking solenoid was an issue with Edit when it first came out way back when. My ute did this. SCT fixed the issue and dealers then updated their software and in turn our tunes to fix the issue. If you've got this issue then I'd guess the software your tuner is using must of never been updated.It's a tune problem. Link to comment Share on other sites More sharing options...
Mr Man Mad Scientist Member 816 Member For: 20y 2m 19d Gender: Male Location: Vic Posted 24/04/09 12:53 PM Share Posted 24/04/09 12:53 PM It's a tune problem. Link to comment Share on other sites More sharing options...
BB. Member 69 Member For: 17y 4m 16d Gender: Male Location: Mildura Posted 24/04/09 12:59 PM Share Posted 24/04/09 12:59 PM Link to comment Share on other sites More sharing options...
seventytwo Still have a turbo, it's just on a diesel. Lifetime Members 5,368 Member For: 19y 7m 10d Gender: Male Location: The 8th Dimension Posted 24/04/09 01:26 PM Share Posted 24/04/09 01:26 PM Link to comment Share on other sites More sharing options...
01txr Member 861 Member For: 18y 1m 3d Gender: Male Location: QLD Posted 24/04/09 02:07 PM Share Posted 24/04/09 02:07 PM If you are using Xcal 2 or 3 , when you load in your tune select user options and adjust wastegate Duty to 100%.That fixed mine, it is appranetly something to do with settings in the tune.You have to adjust the other settings to suit if you want to run less wastegate duty.A experienced tuner should know this. If you want to run less boost you will needto tell your tuner to make the adjustments to suit what duty you want to run.All I need to find out with mine once my new turbo and manifold go on is why with my adaptive learningturned off my car keeps adjusting itself to 10.9AFR's at 0% Throttle Position, Idle of Throttle cruise. Link to comment Share on other sites More sharing options...
MYBAXRT Member 158 Member For: 15y 11m 12d Gender: Male Location: nowra Posted 24/04/09 10:27 PM Share Posted 24/04/09 10:27 PM Have another read of the other thread you started Robert, they were not saying it is the solenoid that is the problem. seventytwo suggested that it may be something in the tune that is affecting the boost solenoid. Flash the car back to the stock tune and have a listen to see if you still get the same sound, and let us know :angel:the tune has been update 3 times now thay even gave me the 10psi tune to try out and its doing the same thing. but not when its on stock but when I put the tune on the boost solanoid starts buzzing.... Link to comment Share on other sites More sharing options...
