  • Member For: 17y 3m 10d
I gave this a bash last night. book the battery out because I have big hands. did not take long have it a hit with WD40 gave it some time. went out was a bit better. then smacked it and must of blown the crap out because after that it just hammered. more response was great fun I wish I had more fuel lol. if u have not done this you should.
  • 3 weeks later...
  • Member For: 17y 4m 5d
I just finished doing this.
It wasn't very hard at all. I wasn't too sure on how much WD40 I should actually put in. I didn't want to over do it.
Took it for a quick spin but didn't really notice anything major. I will take it for a longer drive tomorrow.
  • Member For: 17y 1m 22d
just finshed doin this its so easy and test drove it boost comes on so much earlyer and car go so much stronger realii worth doin thanks guys
  • disgruntled member
same, just did it, took 10 mins lol, easy as **** and yeah boosting earlier......thanks for the info
  • rob327
  • Member For: 17y 3m 7d
Urgent help needed... car in pieces...
cant get the hose off... is the metal clamp meant to be destroyed?
stressful.... fat hands... had to take the battery out and the pipes off the x-over.. and its still a bitch to get near...
  • rob327
crisis everted...... I used all my angst and ripped the hose off.... suprised it went on so easy given how much of a :stupid: it was to get off
  • 2 weeks later...
  • 3 weeks later...
  • Member For: 17y 4d
hi fellows just tried the boost solenoid clean it did make a little bit of a diff but not as much as I was expecting maybe I didnt spray enough wd40 how much did u guys use how long did u spray a couple of seconds or a couple of minutes.
also if any one is having trouble getting the hose that runs from the solenoid to under the turbo to stay on just use a small cable tie does the trick
  • Member For: 21y 4m 7d
Adam,
This job is not designed to increase power, only restore lost power.
The main noticable difference is the boost comes on quicker, it does not increase the boost.
I need to do it to my car again as the boost feels lazy or laggy.
You only need to spray for 2 seconds as you want to lubricate, not flood the solinoid.
Hope this helps.
