  • Member For: 18y 10m 16d
thanks zap f6,did mine today along with the difillipo turbo pipes,makes a nice improvement,took 5 min didint need to take the battery out,just used a long pair of pliers very easy
thanks lee
  • Member For: 18y 7m 5d
  BA_XR6Turbo_Ute said:
Just for those who are mechanically challanged, for the battery when disconnecting which terminal do I take of first and which do I put on first when reconnecting
cheers
neg of first on last!! :w00t2::w00t2:
  • Like 2
  • Member For: 19y 7m 6d
Ok guys got everything done except for getting that baslted little hose off
The clamp had a bit of rust on it so I didn't wanna pull it off otherwise I thought I'd break the hose or something.
Put everything back together. I then thought wouldn't it be easier to put a t peice further on on the hose that connects to the boost solenoid and install the t peice of some sort then access would be easier.
Just an idea. Perhaps someone more mechincally minded could say if this is a viable solution
I have attached a picture with my idea
EDIT:
blue t squiggle is the proposed t peice and red circle is where I thought I could be located. Of course there would be some sort of thing to block the 3rd hole on the t peice
feedback???
Edited by BA_XR6Turbo_Ute
  • Im the one and only
  • Member For: 20y 3m 4d
We tried it last night on my mates stock T and it made a difference for sure.Coming on boost earlier in higher gears which is what he said was originally lacking.
Cheers fellas :msm:
  • Member For: 21y 1m 28d
I guess you could put a T piece on, but the removal of the hose is easy.
Just grab the hose above the clamp and twist 'n pull it straight off.
The clamp does not hold the hose on much as there is not a lot of pressure running through the hose.
I am glad people are finding this a good maintenance procedure as it will make a noticable difference to the performance.
  • Member For: 19y 11m 17d
Hi guys this is my first post on here, so I hope you will go easy on me. Iv ahd a T for about 6 months now and love the car!! I tried this but the other end of the hose came of, im not sure where it goes. Could some on instruct me on where it fits or could someone take a picture. it would be even grater help. Thanks alot
There are 2 hoses that run on to the solinoid.Is it the top hose or the bottom?
  • Member For: 19y 9m 3d
EDIT:
feedback???
haaa I'm calling you Mr squiggle from now on!!!!
good idea, but once you get the hose of once it's not too bad after.
My hose was on so tight that is was actually hard to get back on and I took half the car apart to do it, so I can see why some people have problems. Also the solenoid will unclip from the bracket once you see how the clip works.
A small problem with my T (6sp man) is that when cruising and I put my foot down, sometimes the car doesn't react and then suddenly hits boost and takes off. This may be linked to the solenoid and I'm monitoring if the car does it again.
Great post Zap...... next a guise to manifold torquing. I'll do this in the next month and take some pics. Cheers all!!
  • Member For: 19y 9m 10d
  ZAP_F6 said:
does not make much difference unless you have a factory alarm.
If you do, make sure the ignition is on then remote the + terminal first to avoid the alarm going off.
should always disconnect your negative terminal first
