senna_T Forged Member Lifetime Members 15,818 Member For: 18y 4m 15d Gender: Male Location: SW Sydney Posted 24/12/07 05:07 AM Share Posted 24/12/07 05:07 AM do you mean the clamps that kind of double over themselves, rather than the screw type ones? if so, you should just be able to use some pliers to squeeze it together and pull them off Link to comment https://www.fordxr6turbo.com/forum/topic/31329-boost-solenoid-maintenance/page/19/#findComment-613430 Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 21y 4m 8d Gender: Male Location: Sydney Posted 24/12/07 05:08 AM Author Share Posted 24/12/07 05:08 AM Grab the hose and pull it off.We all have the same clamps and the plastic hose has not ridge, so it slides off with a bit of a twist and pull.Believe me it does slide off and is easy to put back on. Link to comment https://www.fordxr6turbo.com/forum/topic/31329-boost-solenoid-maintenance/page/19/#findComment-613431 Share on other sites More sharing options...
mbjunior99 Member 4,359 Member For: 22y 5m 30d Gender: Male Location: Brisbane Posted 24/12/07 05:32 AM Share Posted 24/12/07 05:32 AM Link to comment https://www.fordxr6turbo.com/forum/topic/31329-boost-solenoid-maintenance/page/19/#findComment-613445 Share on other sites More sharing options...
TUFXRT6 Silver Donating Members 687 Member For: 19y 3m 2d Gender: Male Location: Victoria Posted 24/12/07 05:38 AM Share Posted 24/12/07 05:38 AM Ok boys this is the deal.There was no way the top pipe is coming off without me breaking it. The pipe even came off the in turbo end!!!The bottom pipe came off & is now easy to come on & off which is a worry.RegardsTUFXRT6 Link to comment https://www.fordxr6turbo.com/forum/topic/31329-boost-solenoid-maintenance/page/19/#findComment-613449 Share on other sites More sharing options...
Ernie Member 224 Member For: 18y 2m 10d Gender: Male Location: Sydney Posted 25/12/07 03:30 AM Share Posted 25/12/07 03:30 AM TUFXRT6 said: Ok boys this is the deal.There was no way the top pipe is coming off without me breaking it. The pipe even came off the in turbo end!!!The bottom pipe came off & is now easy to come on & off which is a worry.RegardsTUFXRT6Tuf,it will come off as ive just finished my maintenance about 10 mins ago......... just pri it a little with a small flat screwdriver ( just dont pierce the hose ) and pull with a long nose pliers it will eventually come off.ive just left this message in my asking for advise thread and the first post in this thread is exactly what needs to be done.thanks again.......... the best description on how to do this !bit of a heads up.......guys its all fixed !looks like it was the solenoid sticking as a couple members have said. I followed the instruction on the solenoid maintenance thread and low and behold its fixed. no more surging and I have to say it feels even better than before. more responsive and quicker on the boost.suppose it had to be done after 100,000 of driving without a clean !thanks for the advice............ you guys are legends !Ern Link to comment https://www.fordxr6turbo.com/forum/topic/31329-boost-solenoid-maintenance/page/19/#findComment-613706 Share on other sites More sharing options...
wados Member 617 Member For: 20y 8m 5d Gender: Male Location: brisbane Posted 25/12/07 09:51 PM Share Posted 25/12/07 09:51 PM Superdan said: had you driven it since wados? any comments regarding the difference??Sorry mate for the late reply superdan but was away on holidays.It mad a small difference but not to small that you dont notice it, The change is downlow with boost it comes on a little harder and also in an auto say your doing 60 and you give it a boot full then the boost comes on a little earlier and seems to pull a little harder just for a second or 2. Link to comment https://www.fordxr6turbo.com/forum/topic/31329-boost-solenoid-maintenance/page/19/#findComment-613774 Share on other sites More sharing options...
sneakypete83 Member 4 Member For: 17y 7m 11d Location: Newcastle Posted 27/12/07 11:34 AM Share Posted 27/12/07 11:34 AM Hey all, Brand new member to the forum (new owner), just performed this tweak (admittedly I did have to remove the battery) and got a reasonable response from my BA with 93 grand on the clock. Seems to pull more evenly from lower RPM (used to have a pronounced 'kick' at 3000rpm) and generally has a better response to generous application of the right foot.Great tip, thanks very much, looking forward to getting into the boosted community. Link to comment https://www.fordxr6turbo.com/forum/topic/31329-boost-solenoid-maintenance/page/19/#findComment-614239 Share on other sites More sharing options...
Superdan Well-Hard Bangin' Member Member 3,422 Member For: 17y 10m 2d Gender: Male Location: Perff, WA Posted 27/12/07 01:18 PM Share Posted 27/12/07 01:18 PM hey sneakypete, welcome, welcome, welcome!!!!if you liked this little tip try the throttle body clean out, definately helps out (sorry mate, can't be farked finding it, but I'm sure some nice member will be along shortly with a link!)come say hi in the off-topic thread, well worth itenjoy and welcome to the madhouse!!!!Dan Link to comment https://www.fordxr6turbo.com/forum/topic/31329-boost-solenoid-maintenance/page/19/#findComment-614281 Share on other sites More sharing options...
Chief_XR6T Member 425 Member For: 18y 2m 18d Gender: Female Location: Adelaide Posted 30/12/07 06:24 AM Share Posted 30/12/07 06:24 AM yea the throttle body clean works a treat easy to do as well I was scared at first but easysorry that its AFF but here http://www.fordforums.com.au/showthread.php?t=73561includes info on Throttle Body cleaning and boost solenoid , and Torquing of exuast manifold bolts Link to comment https://www.fordxr6turbo.com/forum/topic/31329-boost-solenoid-maintenance/page/19/#findComment-615143 Share on other sites More sharing options...
Chief_XR6T Member 425 Member For: 18y 2m 18d Gender: Female Location: Adelaide Posted 01/01/08 02:38 PM Share Posted 01/01/08 02:38 PM Just did it todayand it took no effort what so ever to remove the pipe it had a weird clamp on it, didn't have to un clamp it, to put it back on was easy did it with my left hand was a little to easywas wondering is this pipe a suction pipe if so then im fine Link to comment https://www.fordxr6turbo.com/forum/topic/31329-boost-solenoid-maintenance/page/19/#findComment-615858 Share on other sites More sharing options...
