75,000km Service
apac77
  • Member For: 18y 11m 10d
Hi there guys,
Just received a quotation for my 75,000km service.... $1300. This is what it includes:
75,000km Service
- replace engine oil and filter
- check all fluid & top up as required
- carry out ECU self test including idle speed & abs check
- Inspect drive belt
- inspect battery electrolite
- check batter terminal for cleanliness & security
- check engine compartment hoses for leaks, wear & security
- check intake & exhaust manifolds bolts for tightness
- check hood & latch operation
- check exhaust system for security & leaks
- inspect suspension & steering components
- rotate wheels following manufacturers recommended sequence
- check brake system for component wear or leaks
- check condition & pressure of all types including spare
- check wheel nuts for correct tension
- check brake pedal height & hand brake lever operation
- check lights, wiper/washers, horn & electrical systems
- road test vehicle & report any defects
TOTAL: $190.00
Parts
1 x AFLIMC Filter Assy - Oil ($11.76)
1 x R147A - Solution W/S Washer (1.53)
TOTAL: $13.29
Sundries
1x Oil Disposal $8.00
1 x Shop Supplies $11.00
1 x Top Up Fluids $2.00
6.6 x Engine Old $51.15
Total: $72.15
ADJUST HANDBRAKE $95.00
REPLACE REAR BREAK PADS $104.50
- Parts 1 x BA2200A Pad Kit $119.78
REPLACE FRONT BREAK PADS $76.00
- Parts 1 x BA2001A Pad Kit $201.01
REPLACE SPARK PLUGS $114.00
- Parts 1 x AGSP22Z11 Spark Plug $59.34
REPLACE LEFT FRONT FOG LIGHT GLOBE $47.50
- Parts ELB453 Globe H3 55W $17.97
REPLACE RIGHT HEADLAMP GLOBE - $57.00
- Parts SX13466A - Globe H4 60/55W $19.79
TOTAL LABOUR $684.00
TOTAL PARTS: $430.18
TOTAL SUNDRIES: $72.15
TOTAL QUOTE: $1186.33
GST: $118.63
TOTAL INCLUDING GST: $1304.96
FARK ME!!!! Is Labour really that freaking much or am I being shafted. I need all this stuff done to my BA XR6T Sedan (03).
Any advice?
Thanks
Steven
stevenpelham@gmail.com
Edited by Dagabond
  • Member For: 19y 6m 22d
f*ck THAT!!
alot of that crap can be done by you mate..
95$ to adjust a handbrake??? it took me 10 mins all up, and that includes getting the car on and off the ramps..
that is the rudest thing I have ever seen mate. I changed my pads myself and it took an hour.. they werent that expensive either.
advice? never go there again EVER..
  • Member For: 19y 3m 9d
id take it to somewhere like Midas and get a price. they will still give you a nation wide warranty and id expect it to cost close to half the price that ford quoted you for the same job.
Hi guys,
Thanks a heaps for the replies so far... I'll definitely give midas a go, what about Ultra Tune? My bro took his turbo calis to them once, and the cracked the turbo manifold cuz the freaks thrashed it....
Stevo
  • Member For: 18y 5m 8d
:santa2: That is BullS##T mate. Talk to a bunch of people and find out what mechanic they use. The best way to find a good mechanic is word of mouth. As long as he is a legit licensed mechanic and better still registered with MTA then you can get him to do your services without effecting the warranty. I take mine to my local mechanic for the last 10 years. He stamps the service log book and that's that. Whenever there has been a major issue that is covered under warranty that my mechanic finds, I call ford, tell them the problem and they book it in under warranty.
I only use Ford for the warranty. I do everything else through my mechanic and save at least 70% of Fords price + I like the idea he has a T also with phase III so he knows the car inside out. :sleepystuff:
