Fat-Tony Member 5,364 Member For: 18y 8m 4d Posted 14/12/06 09:18 AM Share Posted 14/12/06 09:18 AM Thought you were getting a big intercooler Fat?←The price is right, the fitting is easy, with the level of power I can afford atm, I cant justify going for a bigger item just yet. Ian Link to comment Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 21y 9m 25d Gender: Male Location: Sydney Posted 14/12/06 09:30 PM Share Posted 14/12/06 09:30 PM I have and it takes about an hour if you have a mate that is a mechanic and is prepared do do the lot himself while you sit back and watch.←Good sound advice there Marcus← Link to comment Share on other sites More sharing options...
bugster70 Donating Members 1,326 Member For: 19y 6m 22d Location: Canberra Posted 15/12/06 12:24 AM Share Posted 15/12/06 12:24 AM What you laughing about Mick, anyone would think that YOU'D fitted a Wogcooler while one of YOUR mates sat back to watch/'help'!! :tosser: Link to comment Share on other sites More sharing options...
JimmyXR6T04 Member 1,299 Member For: 19y 5m 5d Location: Canberra Posted 15/12/06 01:37 AM Share Posted 15/12/06 01:37 AM I had my injectors, fuel pump, ASE cooler, clutch re-bleed, spark plugs re-gapped, and gauges all installed by one of my mechanically minded friends. Arggh it was good.. took a little longer then usual due to the beers, but we got there. Or should I say he got there... I just sat around drinking and handing him tools (when I knew which one he wanted) otherwise he'd have to get up and re-fetch the correct size or tool. God bless him :tosser: Not bad considering it cost me a few beers!! Link to comment Share on other sites More sharing options...
Headsex Donating Members 2,528 Member For: 19y 3m 14d Gender: Male Location: Melb Posted 15/12/06 06:14 AM Share Posted 15/12/06 06:14 AM Done mineBeing a MK2, you have to drill the passenger side mount holes, as they changed position between MK1 and MK2 Link to comment Share on other sites More sharing options...
DBOSS Faster than any BTA,XTC,Autotech, Nizpro and Tunehouse car Member 3,918 Member For: 21y 5m 3d Location: D SHIRE! Posted 15/12/06 06:58 AM Share Posted 15/12/06 06:58 AM Anyone fitted a wog cooler?Why the I <3 Bananas would ya Link to comment Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 18y 8m 4d Posted 15/12/06 07:07 AM Share Posted 15/12/06 07:07 AM Didnt you buy one STOOGE Just fitted mine, not included in the instructions are if you got a BF you will need to remove the number plate as there are 2 bolts behind it that you will need to take off to remove bumper, BA mark 2 onwards the passenger side holes will have to be drilled, though I had to modify the top bracket on passenger side as it wasnt long enough, drivers side lower bracket the hole was in the wrong spot, that had to be redrilled. Ahhh loosen the nut on your horns and twist them round so they clear everything, need to slightly bend the air con lines to stop em touching the IC, apart from that, she is a tight fit. Link to comment Share on other sites More sharing options...
jetute Donating Members 4,553 Member For: 20y 9m 24d Gender: Male Location: brisbane Posted 15/12/06 07:08 AM Share Posted 15/12/06 07:08 AM (edited) Anyone fitted a wog cooler?Why the I <3 Bananas would ya ←oh look its another wog thread... lets see who turns it to shiat infact lets post up all wog threads and see whos turned them to shiat... the results may suprise Edited 15/12/06 07:08 AM by jetute Link to comment Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 18y 6m 5d Gender: Male Location: Sydney NSW Posted 15/12/06 07:21 AM Share Posted 15/12/06 07:21 AM Anyone fitted a wog cooler?Why the I <3 Bananas would ya ←Didnt you buy one STOOGE Just fitted mine, not included in the instructions are if you got a BF you will need to remove the number plate as there are 2 bolts behind it that you will need to take off to remove bumper, BA mark 2 onwards the passenger side holes will have to be drilled, though I had to modify the top bracket on passenger side as it wasnt long enough, drivers side lower bracket the hole was in the wrong spot, that had to be redrilled. Ahhh loosen the nut on your horns and twist them round so they clear everything, need to slightly bend the air con lines to stop em touching the IC, apart from that, she is a tight fit.←A tight fit LOL mine, being tripple the size is a tight fit mate Link to comment Share on other sites More sharing options...
Trough Lolly Member 4,349 Member For: 20y 2m 17d Gender: Male Location: Mildura Posted 02/01/07 06:09 AM Share Posted 02/01/07 06:09 AM (edited) fitted one on a mates ute last week, 2 person job is easier as u just dont have enough hands.had to drill 2 holes on the passenger side with a 9mm bit and bend 1 bracket with some multigrips. the bolts could have been 5mm longer though!!oh and hang onto the gold nuts from the stock cooler, as youll need to use them as monza the tightasses dont give u any.as for horns, bolt the gold "Y" piece up as normal, but put the horns on the other side of the bracket then bend them back towards the cooler an inch or so. their still visible from the top grille, unless u wanna make a longer lead and mount them elsewhere. Edited 02/01/07 06:11 AM by Trough Lolly Link to comment Share on other sites More sharing options...
