LUMO Donating Members 476 Member For: 17y 8m 30d Gender: Male Location: SYDNEY Posted 05/06/07 02:24 PM Share Posted 05/06/07 02:24 PM I was thinking about having mine extrusion honed top and bottom.what do u guys think what do you mean by that? Link to comment Share on other sites More sharing options...
INFLYT Donating Members 784 Member For: 18y 4m 3d Gender: Male Location: N.S.W, Sydney Posted 08/06/07 05:44 AM Share Posted 08/06/07 05:44 AM what do you mean by that?Extrude Hone. Basically it's the art of pushing paste through something to clear any imperfection's that can affect flow. It look's like someone's laying cable, when you look at it being done... Link to comment Share on other sites More sharing options...
LUMO Donating Members 476 Member For: 17y 8m 30d Gender: Male Location: SYDNEY Posted 08/06/07 06:03 AM Share Posted 08/06/07 06:03 AM (edited) Extrude Hone. Basically it's the art of pushing paste through something to clear any imperfection's that can affect flow. It look's like someone's laying cable, when you look at it being done...Hi IGZStill dont understand what it does and what gets done to the manifold.By the way boys I have start my manifold mod so far so good. myn will be bit different but I amd changing that centre part on the manifold and put a rectangular peace on alloy to replay the have my flage on top.The reason for this is to have my pipes to be under the ecu I dont like the look of the pipes being higher that the ecu,here is a pic of what my idea is. As soon as its ready for welding ill post pics to give you a rough idea what it looks like Tell me what you think.Cheers Pete Edited 08/06/07 06:06 AM by LUMO Link to comment Share on other sites More sharing options...
INFLYT Donating Members 784 Member For: 18y 4m 3d Gender: Male Location: N.S.W, Sydney Posted 08/06/07 06:14 AM Share Posted 08/06/07 06:14 AM This would probably describe it a little better man;"What they do is pump an abrasive thick substance, best described as being like toothpaste, through item's like intake or exhaust manifolds to "port" them. It is very good at removing the rough surface finish from sandcasted items, either cast Aluminium or cast Iron, and leaves a beautiful satin finish. The great thing with it is that it removes more material around to locations of the greatest restriction and so will tend to even out the restriction through a manifold." Link to comment Share on other sites More sharing options...
LUMO Donating Members 476 Member For: 17y 8m 30d Gender: Male Location: SYDNEY Posted 08/06/07 06:19 AM Share Posted 08/06/07 06:19 AM This would probably describe it a little better man;"What they do is pump an abrasive thick substance, best described as being like toothpaste, through item's like intake or exhaust manifolds to "port" them. It is very good at removing the rough surface finish from sandcasted items, either cast Aluminium or cast Iron, and leaves a beautiful satin finish. The great thing with it is that it removes more material around to locations of the greatest restriction and so will tend to even out the restriction through a manifold."Thanks man that's alot better haha. Any idea on how much something like that will be worth to do?Cheers Pete Link to comment Share on other sites More sharing options...
cobrav8 Member 1,969 Member For: 19y 7m 21d Gender: Male Location: New Zealand Posted 08/06/07 06:24 AM Share Posted 08/06/07 06:24 AM (edited) Hi IGZStill dont understand what it does and what gets done to the manifold.By the way boys I have start my manifold mod so far so good. myn will be bit different but I amd changing that centre part on the manifold and put a rectangular peace on alloy to replay the have my flage on top.The reason for this is to have my pipes to be under the ecu I dont like the look of the pipes being higher that the ecu,here is a pic of what my idea is. As soon as its ready for welding ill post pics to give you a rough idea what it looks like Tell me what you think.Cheers PeteThe idea of the pipe - fine - but having the filter box on top of the engine is just silly - imagine the size hole you will have to cut in the bonnet! Edited 08/06/07 06:24 AM by cobrav8 Link to comment Share on other sites More sharing options...
LUMO Donating Members 476 Member For: 17y 8m 30d Gender: Male Location: SYDNEY Posted 08/06/07 06:30 AM Share Posted 08/06/07 06:30 AM The idea of the pipe - fine - but having the filter box on top of the engine is just silly - imagine the size hole you will have to cut in the bonnet! Its not silly think about it, another air intake ill be cutting it open like the WRX mail box they have on there bonnetdont worry it will go fast Link to comment Share on other sites More sharing options...
XR06T Silver Donating Members 4,146 Member For: 19y 4m 22d Gender: Male Posted 11/06/07 04:21 AM Share Posted 11/06/07 04:21 AM is there going to be enough room for the throttle body on the plenum? I think this is the problem exah6 ran into, then added that pipe with the tb on the end of that..looks good either way! Link to comment Share on other sites More sharing options...
LUMO Donating Members 476 Member For: 17y 8m 30d Gender: Male Location: SYDNEY Posted 11/06/07 04:33 AM Share Posted 11/06/07 04:33 AM is there going to be enough room for the throttle body on the plenum? I think this is the problem exah6 ran into, then added that pipe with the tb on the end of that..looks good either way!I might be able to get the TB straight on the plenum I have to wait till its welded and on the car to be sure Link to comment Share on other sites More sharing options...
XR06T Silver Donating Members 4,146 Member For: 19y 4m 22d Gender: Male Posted 12/06/07 01:25 AM Share Posted 12/06/07 01:25 AM cool, just saw your pics in the other thread and it looks like a trick setup, let us know how it goes! Link to comment Share on other sites More sharing options...
