ExAreSix TRAITOR Member 1,063 Member For: 22y 3m 27d Gender: Male Location: Townsville, NQ Posted 12/12/06 02:33 PM Author Share Posted 12/12/06 02:33 PM Is that flywheel kw?300rwkw is where you want to be.←No, that's rwkw.320 is where I want to be. And as soon as I get to Sydney, all the bits that have been sitting waiting to go on for the last 6 mths, will finally be put into her, and tuned.I know what you're thinking, seems a little high for stock injectors, and I concur. I'd say the dyno is atleast 10kw generous going by other results on the same dyno, same day.But, I think it speaks a million words of how worthwhile custom plumbing and cooler is. Keep in mind these are generic tunes, and the car has never been touched by anyone other than myself. The result was quite a surprise to me, and very satisfying.Actually, the pipe that goes under the headlight and battery tray is the intercooler return to the throttle body the turbo pipe is rubber and runs down low, you can hardly see itDanCorrect. So, Fat-Tony, the 2.5 inch pipe you see pictured, going under the passenger headlight is essentially the replacement for the pipe that goes under the drivers headlight in the factory setup. And is roughly double the diameter of the factory pipe.Looks good, the plastic pipe should be fine as long as its not getting too hot... my volvo 850R had plastic IC pipes and they lasted years, until I took them off lolhigh 13s man that's dangerously lean, atleast your intake temps arnt as hot with the bigger IC, but Id be flashing it back to stock until it gets tunedHows it feel on road?High 13s are dangerous, I know this. That was the 10psi tune which has only been loaded once for the dyno run, for comparison.Hows it feel? Great. Bit laggy due to tune (but much crisper than before the cooler and pipes keep in mind). 3rd gear gives a satisfying 'wiggle' when given WOT. Link to comment Share on other sites More sharing options...
saleen Big Gun Donating Members 4,170 Member For: 22y 4m 5d Gender: Male Location: NSW Posted 12/12/06 03:03 PM Share Posted 12/12/06 03:03 PM Is that flywheel kw?300rwkw is where you want to be.←I know what you're thinking, seems a little high for stock injectors, and I concur. I'd say the dyno is atleast 10kw generous going by other results on the same dyno, same day.I wasn't thinking that really. The true measure will be how it performs at the track I guess. A leaner mixture will generally read higher, but get those AFR's fixed though and you'll be right. Link to comment Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 18y 10m 26d Posted 12/12/06 11:18 PM Share Posted 12/12/06 11:18 PM ExAreSix where did you locate the MAP sensor that was in the pipe? Ohh and I had a look under my bonnet and actually took notice of the cooler pipes this morning Link to comment Share on other sites More sharing options...
ExAreSix TRAITOR Member 1,063 Member For: 22y 3m 27d Gender: Male Location: Townsville, NQ Posted 13/12/06 02:25 AM Author Share Posted 13/12/06 02:25 AM ExAreSix where did you locate the MAP sensor that was in the pipe? Ohh and I had a look under my bonnet and actually took notice of the cooler pipes this morning ←Right there *points* Link to comment Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 18y 8m 27d Gender: Male Location: Sydney NSW Posted 13/12/06 08:05 AM Share Posted 13/12/06 08:05 AM Dont expect too much more power on the dyno with the big cooler/pipes... you should get similar power on a few psi less if it still retains the stock exhaust Link to comment Share on other sites More sharing options...
ExAreSix TRAITOR Member 1,063 Member For: 22y 3m 27d Gender: Male Location: Townsville, NQ Posted 13/12/06 08:32 AM Author Share Posted 13/12/06 08:32 AM 3.5inch X-Force system should do fine, thanks. Link to comment Share on other sites More sharing options...
Muzza No V6 for me thanks!! Donating Members 583 Member For: 19y 6m 10d Location: Newcastle Posted 13/12/06 08:34 AM Share Posted 13/12/06 08:34 AM Is the the N/A pipe off the throtle body?? If so it won't last, sorry.All looks goods. Muzza Link to comment Share on other sites More sharing options...
ExAreSix TRAITOR Member 1,063 Member For: 22y 3m 27d Gender: Male Location: Townsville, NQ Posted 13/12/06 08:44 AM Author Share Posted 13/12/06 08:44 AM (edited) Is the the N/A pipe off the throtle body?? If so it won't last, sorry.All looks goods. Muzza←Oh? Have a look at the pic...EDIT: I mean, please share why it won't last? Edited 13/12/06 08:45 AM by ExAreSix Link to comment Share on other sites More sharing options...
saleen Big Gun Donating Members 4,170 Member For: 22y 4m 5d Gender: Male Location: NSW Posted 13/12/06 08:50 AM Share Posted 13/12/06 08:50 AM 3.5inch X-Force system should do fine, thanks. ←I could have sold you a 4 inch at a fraction of what you paid. Link to comment Share on other sites More sharing options...
ExAreSix TRAITOR Member 1,063 Member For: 22y 3m 27d Gender: Male Location: Townsville, NQ Posted 14/12/06 08:19 AM Author Share Posted 14/12/06 08:19 AM You weren't selling your system 6 mths ago.I love my Xforce system. Link to comment Share on other sites More sharing options...
