  • Member For: 18y 11m 28d
Hey all,
What sensors should I try and tap into for data logging and real time display for my carputer project.
Should I install separate sensors or try and tap into existing ones.
How many MAP sensors does the T have? and does anyone know there output voltage range?
https://www.fordxr6turbo.com/forum/topic/30860-tapping-in-to-car-sensors/
  • Member For: 18y 9m 27d
This is what I use to check all the sensors. I get all the sensor information from the cars OBD port into my Laptop Computer.
The information is in real time. :spoton:
The software I use:
Proscan v 4.0
Digimoto v 4.03
Pcmscan v 1.4.3
AutoTap v 3
Edited by 937
I didnt think OBD2 could read the extra sensors such as boost, only a CAN device could.
CAN devices a 200+ for something very basic that is interfaced though a com port and dosnt come with any software
Edited by crans
  • Member For: 19y 6m
Hi 937, can you tell me if you can measure the following:
Boost
Cam Adjusters
Both MAP sensors
Fuel Pressure
Oil Temp
Transmission Oil Temp
Cheers
(Sorry if this is a bit of a hijack)
To answer your question, I would try and tap into the original sensors. I would think they would have a +5v range, but I could be wrong.
  • - Track Bound EVO III -
  • Member For: 20y 4m 15d
CAN is only a protocol, and it's read from the OBDII port, just like the other protocols.
As for boost, Oil Temp etc, you will need a more advanced scanner than 937 uses. ( still CAN, and still read from the OBDII port )
I also have a basic scanner, Autoenginuity but that's a bit more exxy than 937's. He has the shareware software ( just as good ) but they can't read as many sensors as the SCT/CAPA data logger.
The best you get from BF is CAT temps, and general temps like ambient/coolant and air intake with the basic scanners....
  • Member For: 21y 10m 3d
So what would be the best value for money mapping tool to get? Outside of the SCT product of course.
This would be handy to have for fine tuning as well as displaying the data on the screen.
If I can find an adaptor for a decient price im going to write my own software for the monitoring and data logging.
Anyone wanna lend me theres for a few weeks?
Edited by crans
Go to Multiplexs' website :blush:
  crans said:
whats the address
How are you off for socks and undies??
You can program your own data logging software but can't enter www.google.com to find a webpage :blush:
