  • - Track Bound EVO III -
  • Member For: 20y 5m 25d
I did a Zap :blush: ... As I was holding the tx and the Heli at the same time, I accidentally pushed throttle up to max with my shirt, causing un-unnecessary pain to my arm.. Damn those little bastids can do some damage..
  • Replies 103
Posted Images
Guest newl
  • Guests
General rules to abide by:
a) Always perform a preflight inspection of your model, checking for loose connections, connecting rods (bindings, travel).
b) Turn on your radio first, reset all switches and controls to their normal position, throttle to the minimum (with maybe a little trim for the first start for those that have other than electric).
c) Turn on your receiver second with the TX on the ground. This allows you to use both hands, one to hold the head, the other to enable the switch. Switch hand moves away first, then the hand holding the head. This allows you to use the switch hand to control the throttle on the TX.
d) When bringing up the head speed, give all controls a twitch (aileron, rudder, pitch) to verify that they're operating correctly (which is normally done in step a or b when checking for throw and bindings anyway).
There's a few more I typically follow regarding fuel hoses, boom struts and what have you on my Raptor but those are the basics that should normally be followed and gotten into the habit of doing for not only safe flight but to help prevent such problems as blade strikes against softer tissue. :Doh:
Yes, the good advice always comes after the incident.
Check this out.. I'm pretty pleased with myself for a first time effort....
  • Poison Fish. Poison Fish. TASTY FISH!!!
  • Member For: 22y 2m 26d
WOW!
Super Impressive!
Retard
Lumpy :blink:
WOW!
Super Impressive!
Retard
Lumpy :spoton:
What's your problem?? Apart from the obvious anyway??
Anyhoo, vid too big for U/L
Basically I took off from a bar stool and managed to land it back on said bar stool...
:w00t2::w00t2:
:w00t2:  :w00t2:
Got times slips? I don't believe it til you have time slips...Have you had it on an independent multimeter? How much frequency are you running? I bet it's dangerously close to shorting out!
Lumpy :spoton:
Well this-arvo I started trying to fly toward me :evil:
Not a good thing.. Damn it's hard.. I was plummeting backwards towards the ground but couldn't get my head around 'push the stick the other way idiot' so I hit the deck.. No damage though..
I have hovering and general control A1. I can fly backwards no problems at all, even at speed I'm good a that.
Just gotta try some figure 8's I suppose and get the hang of it.
I've also landed on the barstool a few times which is very impressive for such a touchy machine.. :unsure:
Very time consuming just to get basic flight control, but I'm determined to get my little beastie to do a stall turn by christmas.. :w00t2:
  • Member For: 19y 2m 17d
what iv found is if u cant do nose in fly across the front of u go left then right and u can start adding pitch left as u rudder left and start doing banking turns.
like doing figure 8s in front of u theres not much nose in in this manouver and once u master it its like second nature :spoton:
Sweet, I'm charged up and about to head outside so I'll give it a go.
:stupid:
