  • Member For: 20y 3m 9d
Hey Guys, I need some advice, started the T this morning and all going fine until she start idling aroung 2200rpm engine light comes on and car will not go any higher than around 40kmh, engine light still on, tried restarting three or four times and reflashing back to factory setting but no change, it also running rough.
Does anyone have any idea as to what may cause this, any help appreciated.
Thanks
Deano
https://www.fordxr6turbo.com/forum/topic/30715-engine-light-on/
  • My new toy
  • Member For: 22y 19d
Check to make sure there are no hoses off in the engine bay.
The main one is the pcv valve hose at the back of the rocker cover on drivers side and goes across to the left side under throttle body.
Ian
Yeah thanks guys, it turned out that the throttle body and the throttle position senser had to be replaced.
All ok after warranty fix.
Deano
