chooch Member 256 Member For: 21y 1m 8d Location: Adelaide Posted 27/11/06 11:30 AM Share Posted 27/11/06 11:30 AM (edited) Hey peoples, I am getting slight vibration I can feel through the steering wheel when the tyres are cold. it usualy dissapears after about 10 minutes of driving.I did hit a pothole 12 months ago that dented a rim (18" ford rims with standard dunlops), which was replaced under insurance but I can still feel a slight vibration only when the tryes are cold. Ford claim they can't see or feel anything wrong.........but I can tell there is.Obviously I have had the tryes rotated/balance/alligned, many times. I have tried changing the tyre pressures also, they normally sit at 38psi (on recommandation from some noob tyre bloke in my area)any ideas? Edited 27/11/06 11:34 AM by chooch Link to comment Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 21y 6m 7d Gender: Male Location: Southern Highlands NSW Posted 27/11/06 11:38 AM Share Posted 27/11/06 11:38 AM (edited) I understand that your wheel bearings are sealed so you cant adjust the tension on them. I would suggest that you jack up the car so the front wheel is off the ground and see if there is any play in the bearings.As the temp in the bearings rise they expand so this could be the reason why its going away..Might also be an ideal to take it to a tyre place and get the wheels re balanced at another NOOB tyre joint Edited 27/11/06 11:38 AM by revheadrobbo Link to comment Share on other sites More sharing options...
mattyc Member 141 Member For: 22y 5m 2d Posted 27/11/06 11:47 AM Share Posted 27/11/06 11:47 AM Hey ive got the same problem. Mine are 17" std dunlops, does it for about 1km - but only when I've left it for a day sitting there. Link to comment Share on other sites More sharing options...
Iconic Bionic My engine bay is Bionic Donating Members 3,726 Member For: 18y 11m 21d Gender: Male Location: Freeways Posted 27/11/06 11:50 AM Share Posted 27/11/06 11:50 AM (edited) Im wondering if you have defective tyre, whereby it feels lumpy when you run your hand over it and not flat and smooth. This is more common with cars that have worn out or old suspension and cant keep continual downforce on the tyre and the tyre infact develops lumps accross the tread. These are usually very noticble when you simply run your hand accross the surface of the tyre and compare it with a tyre that is unaffected, in your case, use your rears.Juts my stab in the dark. Edited 27/11/06 11:51 AM by Iconic Bionic Link to comment Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 21y 26d Gender: Male Location: Sydney Posted 27/11/06 12:06 PM Share Posted 27/11/06 12:06 PM Go to a big tyre place and ask for an oncar balance (OCB). They will have a little machine that spins the wheel while still on the car up to 180 km/h and will detect any problem with the wheel/tyres or rotors.It will cost more than your average balance, but it will also tell you is something is not round. Link to comment Share on other sites More sharing options...
BA-PHOON Member 67 Member For: 20y 2m 17d Posted 27/11/06 12:06 PM Share Posted 27/11/06 12:06 PM Hey ive got the same problem. Mine are 17" std dunlops, does it for about 1km - but only when I've left it for a day sitting there.←I have had a similar problem and it turned out to be the tyres getting very minor flatspots on them if the car sat still for longer than a couple of days (I travel for work often and the car sits at home) - it seemed to get worse as the tyres got older?? - new tyres (same type) problem seems to have gone.I wonder whether the tyres get harder as they get older and become more easily flat-spotted??Anyway, I think it sounds like a tyre problem similar to what I had.....hope that helps?? Link to comment Share on other sites More sharing options...
Orrie Member 68 Member For: 19y 7m 22d Gender: Male Posted 27/11/06 12:09 PM Share Posted 27/11/06 12:09 PM Hey ive got the same problem. Mine are 17" std dunlops, does it for about 1km - but only when I've left it for a day sitting there.←I have a similar problem as well - BF MK11 - Brand New - have had a vibration through the car since new. Been in for 3 balances and rotation of tyres etc. Last time there was a big improvement for 40km's. The next day the same vibration+hum was there again until I inadvertently ran over the ripple stripes on the side of the road for about 3 seconds and then it has been good again for about 150km's. I was convinced it was a dud tyre untilk the ripple strip thing and now it has got me really baffled. Just going to monitor it for a while and see. Just P's me off when this sort of crap happens with a brand new car. On a +ve note had a custom tune done last Friday with K&N filter - 260 rkkw and very happy with the performance now! Link to comment Share on other sites More sharing options...
chooch Member 256 Member For: 21y 1m 8d Location: Adelaide Posted 27/11/06 12:15 PM Author Share Posted 27/11/06 12:15 PM wow, lots of good advice. everything mentioned does make sense.I reckon I will try this on car balance thingy (it's not really a dyno in disguise?) Link to comment Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 21y 26d Gender: Male Location: Sydney Posted 27/11/06 12:23 PM Share Posted 27/11/06 12:23 PM nah mate it looks like a little ride on trolly with a steel wheel at the front.Normal wheel balancing is only up to 80km/h.I used to get the OCB done on my racecar as it made it smooth at high speeds. Link to comment Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 21y 6m 7d Gender: Male Location: Southern Highlands NSW Posted 27/11/06 12:26 PM Share Posted 27/11/06 12:26 PM Go to a big tyre place and ask for an oncar balance (OCB). They will have a little machine that spins the wheel while still on the car up to 180 km/h and will detect any problem with the wheel/tyres or rotors.←Cool.. Well you do learn somehting new everyday Link to comment Share on other sites More sharing options...
