tab Sucker Moderating Team 32,303 Member For: 20y 9m 8d Gender: Male Location: Brisbane Posted 12/12/06 11:40 AM Share Posted 12/12/06 11:40 AM Why would you want it though? To cool the water sitting in the radiator? Link to comment Share on other sites More sharing options...
SpudMuffin Member 83 Member For: 21y 1m 26d Location: Joondalup, WA Posted 17/12/06 02:23 AM Share Posted 17/12/06 02:23 AM Would there be a danger in cooling an engine too quickly? I'd hate to think a head was cracked because too cold water was moving around an engine that wasn't producing any more heat. Link to comment Share on other sites More sharing options...
ExAreSix TRAITOR Member 1,063 Member For: 22y 3m 14d Gender: Male Location: Townsville, NQ Posted 17/12/06 02:45 AM Share Posted 17/12/06 02:45 AM Would there be a danger in cooling an engine too quickly? I'd hate to think a head was cracked because too cold water was moving around an engine that wasn't producing any more heat.←There wouldn't be any coolant flowing through the engine. Your water pump is an ancillary, only runs while the engine turns.Thus, I see no point to the excercise. If you want air flow through the engine bay, get a high airflow 12 cm fan on a timer as an exhaust fan. Link to comment Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 20y 9m 8d Gender: Male Location: Brisbane Posted 17/12/06 06:28 AM Share Posted 17/12/06 06:28 AM Exactly I'm no mekanik (sic) but I can't see what the point of it is with the current cooling system setup. Link to comment Share on other sites More sharing options...
YPURV4 KILL,KILL,KILL,DIE,DIE,DIE, Member 2,813 Member For: 18y 8m 30d Gender: Male Posted 17/12/06 06:53 AM Share Posted 17/12/06 06:53 AM I use a turbo timer and when I drive it hard and the timer is on it lets the cooling fans keep running aswell as leting the turbo slow down.Every other turbo cars use timers why not the BA/BF's Link to comment Share on other sites More sharing options...
SavageF6 Donating Members 1,622 Member For: 20y 9m 15d Gender: Male Location: Sydney Posted 17/12/06 07:16 AM Share Posted 17/12/06 07:16 AM (edited) Don't really need a timer on these cars.The cooling system for the turbo etc 'keeps going' after the engine is switched off. Basically, being water cooled, the water reaches the turbo, cools it a bit and evaporates, and returns through the system including the radiator where it discharges the heat and turns back into water. It then reaches the turbo again, cools it a bit.....The process keeps going until the turbo's cool enough and unable to sustain the process basically.Having said that, after a hard drive I do idle the car for a few mins, to generally let everything cool down to a point of relative equilibrium. That or I take it easy for the last few kms. To me, the sound of hot engine components rapidly cooling down after an abrupt shutdown isn't indicative of 'looking after the car'.Edit: shpellign. Edited 17/12/06 07:21 AM by Spruce Link to comment Share on other sites More sharing options...
J&SXR6T Member 56 Member For: 19y 7m 14d Posted 17/12/06 08:33 AM Share Posted 17/12/06 08:33 AM ...or thermosyphon I believe the use of a turbo timer isn't solely for cooling.If you shut an engine down straight away after a hard blast the turbo is still spinning at incredible speeds but there is no oil flow or pressure to keep the turbo properly lubricated and the turbine shaft floated so damage can quickly occur. If you leave the engine running you are cooling the turbo but you are also slowing the turbo down while still providing oil to lubricate it.←This is true in a plane bush type turbo but the t’s run a ball bearing turbo so the turbine shaft doesn’t need to be floated by oil press so no damage is done. Link to comment Share on other sites More sharing options...
