BALLBREAKER Member 427 Member For: 19y 7m 24d Gender: Male Posted 26/11/06 09:00 AM Share Posted 26/11/06 09:00 AM Hi guys just got a new F6 AUTO,its dead stock other than a new air filter.Last night took her for a drive,.about an hour into the drive,I went over a speed hump & the next thing all the warning light came on,even the d for drive in the dash cluster was flashing & the car had no power ii was like I had the hand brake on.Pulled over & restarted the car again same thing again all lights flashing & no power.So the next thing I did is pull over 2 get sum food 1 hour later I drove off & it was OK no probs at all. Another thing my brakes are all ready squeeeeling as well.CHEERS BB Link to comment Share on other sites More sharing options...
Guest newl Guests Posted 26/11/06 09:04 AM Share Posted 26/11/06 09:04 AM The brake squealing is a 'feature'. It comes on all FPV products and is usually experienced under light braking. Link to comment Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 20y 11m 30d Gender: Male Location: Sydney Posted 26/11/06 09:11 AM Share Posted 26/11/06 09:11 AM My Brembo's have started squeeling under light braking as well.As for the issue you described, it sounds like your car went into Limp mode. Normally, if you shut the car off for a min or so and restart it. It could be a early warning sign, a problem that was caused by the speed hump or the car just threw a hissy fit. I would get Ford to get the error codes as it is not normal. Link to comment Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 5m 25d Gender: Male Location: Zombie Birdhouse Posted 26/11/06 09:38 AM Share Posted 26/11/06 09:38 AM As for the issue you described, it sounds like your car went into Limp mode. ←When my T used to go into limp mode , all dash lights operated as normal Must have been the Chimp Link to comment Share on other sites More sharing options...
BALLBREAKER Member 427 Member For: 19y 7m 24d Gender: Male Posted 26/11/06 09:58 AM Author Share Posted 26/11/06 09:58 AM As for the issue you described, it sounds like your car went into Limp mode. ←When my T used to go into limp mode , all dash lights operated as normal Must have been the Chimp ←LOL yeh chimp.Dont u mean chimps that build them.thanks guys ill call my dealer. Link to comment Share on other sites More sharing options...
BA-PHOON Member 67 Member For: 20y 1m 21d Posted 27/11/06 12:01 PM Share Posted 27/11/06 12:01 PM Hi guys just got a new F6 AUTO,its dead stock other than a new air filter.Last night took her for a drive,.about an hour into the drive,I went over a speed hump & the next thing all the warning light came on,even the d for drive in the dash cluster was flashing & the car had no power ii was like I had the hand brake on.Pulled over & restarted the car again same thing again all lights flashing & no power.So the next thing I did is pull over 2 get sum food 1 hour later I drove off & it was OK no probs at all. Another thing my brakes are all ready squeeeeling as well.CHEERS BB←G'day BALLBREAKER,Here is something I wrote back in 2004 - could your problem be the same??"Picked up my Lightening Strike F6 on Dec 3rd 2004.Build No. 52, first one delivered into Tassie. Brembo's optioned + leather etc.84 km's on the clock at delivery (apparently had 72 km's on the clock when it arrived to dealer.... 12 km's 'extra' for window tint etc.)...Drove 35 km's and the dash started playing up. Both the speedo and tacho dropping to zero, despite travelling in fourth gear at around 100 km/hr. Also a 'lot' of lights flashing (check engine, traction control, oil pressure, fuel, temperature, seatbelts etc, etc) Took it back to the dealer, where it spent the weekend before getting fixed on Monday the 6th. They found a loose plug connector on the 'ICC'?? (computer on the inside firewall behind the console)...Not a great way to start!!!"...hope this might help???? Link to comment Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 18y 10m 23d Posted 27/11/06 11:00 PM Share Posted 27/11/06 11:00 PM Sell it Link to comment Share on other sites More sharing options...
BALLBREAKER Member 427 Member For: 19y 7m 24d Gender: Male Posted 25/12/06 12:50 AM Author Share Posted 25/12/06 12:50 AM Hi guys just got a new F6 AUTO,its dead stock other than a new air filter.Last night took her for a drive,.about an hour into the drive,I went over a speed hump & the next thing all the warning light came on,even the d for drive in the dash cluster was flashing & the car had no power ii was like I had the hand brake on.Pulled over & restarted the car again same thing again all lights flashing & no power.So the next thing I did is pull over 2 get sum food 1 hour later I drove off & it was OK no probs at all. Another thing my brakes are all ready squeeeeling as well.CHEERS BB←G'day BALLBREAKER,Here is something I wrote back in 2004 - could your problem be the same??"Picked up my Lightening Strike F6 on Dec 3rd 2004.Build No. 52, first one delivered into Tassie. Brembo's optioned + leather etc.84 km's on the clock at delivery (apparently had 72 km's on the clock when it arrived to dealer.... 12 km's 'extra' for window tint etc.)...Drove 35 km's and the dash started playing up. Both the speedo and tacho dropping to zero, despite travelling in fourth gear at around 100 km/hr. Also a 'lot' of lights flashing (check engine, traction control, oil pressure, fuel, temperature, seatbelts etc, etc) Took it back to the dealer, where it spent the weekend before getting fixed on Monday the 6th. They found a loose plug connector on the 'ICC'?? (computer on the inside firewall behind the console)...Not a great way to start!!!"...hope this might help????←Hi mate sounds like the same problem,but did u lose power as well I mean I lost all power,its a 6 speed auto.sorry for the late reply. CHEERS BB MERRY CHRISTMAS Link to comment Share on other sites More sharing options...
xrdreaming Lifetime Members 1,693 Member For: 22y 14d Gender: Male Location: Melbourne Posted 25/12/06 01:57 AM Share Posted 25/12/06 01:57 AM Mate check the earth connectors just next to or under the battery. They can cause all soughts of gremlins like that. Link to comment Share on other sites More sharing options...
simonhoare Member 85 Member For: 18y 5m 6d Location: S.A Posted 25/12/06 06:13 AM Share Posted 25/12/06 06:13 AM yep its one of main loom plugs happens alot and brembos arnt made for lite bracking expect them to squeel :holiday: Link to comment Share on other sites More sharing options...
