jetute Donating Members 4,553 Member For: 20y 10m 25d Gender: Male Location: brisbane Posted 02/12/06 06:45 AM Share Posted 02/12/06 06:45 AM (edited) Car was on the same dyno with wog today in brissie @ FIST.Earlier this week got new clamps on all teh intercooler hoses and done a full service etc etc etc.I will scan in graph on monday. But yep its down on power and boost is all over the place and cant make as much boost as it did before.Boost is up and down then holds it steady (but low)So its either actuator? or turbo or mani bolts??? (I'd think I'd hear that) (but you had that too did you Mika and didnt notice?)cheers for all the positive feedback in here and things to look at fellas.And piss off to all the useless muppets that jump to conclusions.:D :D :DMick←nope, he couldnt tell until it was opened up... if the bolts are missing or lose you wont hear it... it just drains the power and it wont hold boost as commanded. He had a 40 rwkw gain when bolts were replaced and tightened.cheers Edited 02/12/06 06:46 AM by jetute Link to comment Share on other sites More sharing options...
wrxkilla Member 106 Member For: 18y 6m Posted 02/12/06 06:47 AM Author Share Posted 02/12/06 06:47 AM ripperah well.conesnsus is it will be that or possibly actuator.So I'll get actuator anyway as you gotta pop turbo off to do it.:D Link to comment Share on other sites More sharing options...
DBOSS Faster than any BTA,XTC,Autotech, Nizpro and Tunehouse car Member 3,918 Member For: 21y 6m 4d Location: D SHIRE! Posted 02/12/06 11:44 PM Share Posted 02/12/06 11:44 PM conesnsus is it will be that or possibly actuator.So I'll get actuator anyway as you gotta pop turbo off to do it.:D←Funny that Dynowog does'nt even put actuators in his 320-360 rwklw kits as he said there not needed or fuel pumps Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 8m Gender: Male Location: Victoria Posted 02/12/06 11:54 PM Share Posted 02/12/06 11:54 PM conesnsus is it will be that or possibly actuator.So I'll get actuator anyway as you gotta pop turbo off to do it.You should be able to test the actuator.Don't just go to the expense of changing it without being sure that's the problem.If the actuator spring had lost it's tension I couldn't see how it would hold boost one minute and then not the next. Link to comment Share on other sites More sharing options...
Romulus Donating Members 1,279 Member For: 19y 11m 22d Location: Perth Posted 03/12/06 12:04 AM Share Posted 03/12/06 12:04 AM conesnsus is it will be that or possibly actuator.So I'll get actuator anyway as you gotta pop turbo off to do it.:D←Funny that Dynowog does'nt even put actuators in his 320-360 rwklw kits as he said there not needed or fuel pumps ←Yeah funny that, some *beep* think that no boost control = good tuning Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 8m Gender: Male Location: Victoria Posted 03/12/06 12:11 AM Share Posted 03/12/06 12:11 AM Jason, didn't you do some tests on your actuator to see if it was working properly? Link to comment Share on other sites More sharing options...
Romulus Donating Members 1,279 Member For: 19y 11m 22d Location: Perth Posted 03/12/06 12:24 AM Share Posted 03/12/06 12:24 AM Jason, didn't you do some tests on your actuator to see if it was working properly?←Yes, although mine was more lack of minimum boost and exhaust related issues. However, I recently did some troubleshooting on another T with boost issues. The problem with that car was the lack of response under 3500rpm but no issues with peak power. You could see on the dyno graph exactly when the power shot up.As it turned out, the car had a 8psi actuator installed but there wasn't enough preload on the wastegate swingvalve assembly. What that did was allow the swing valve to remain partially open causing the exhaust gases to bleed-off through the wastegate port, starving the turbine wheel of the gass it needs to spin. Hence the lack of response down low. Link to comment Share on other sites More sharing options...
RAPHOON Donating Members 1,776 Member For: 21y 5m 28d Posted 03/12/06 01:32 AM Share Posted 03/12/06 01:32 AM lol honestly.theres some thick *beep* on this forum.and some useful *beep*.Im bringing the car down to c&v so they can throw nos on it.Should solve all my issues.....Car was on the same dyno with wog today in brissie @ FIST.Earlier this week got new clamps on all teh intercooler hoses and done a full service etc etc etc.I will scan in graph on monday. But yep its down on power and boost is all over the place and cant make as much boost as it did before.Boost is up and down then holds it steady (but low)So its either actuator? or turbo or mani bolts??? (I'd think I'd hear that) (but you had that too did you Mika and didnt notice?)cheers for all the positive feedback in here and things to look at fellas.And piss off to all the useless muppets that jump to conclusions.:D :D :DMick←Sound very similar to the issue I had.We decided to change the actuator and found the issue whilst taking the turbo out. The car would not have needed the actuator change but since we were there.....Just waiting for the clutch and surge tank now so we can finalise the tune. Hmmmm all that grunt on pump fuel. On tap all the time and not just till the bottle runs out. Link to comment Share on other sites More sharing options...
wrxkilla Member 106 Member For: 18y 6m Posted 03/12/06 05:39 AM Author Share Posted 03/12/06 05:39 AM conesnsus is it will be that or possibly actuator.So I'll get actuator anyway as you gotta pop turbo off to do it.:D←Funny that Dynowog does'nt even put actuators in his 320-360 rwklw kits as he said there not needed or fuel pumps ←funny its not dyno wog that's recomended it.go turn up your blue bottlelol Link to comment Share on other sites More sharing options...
wrxkilla Member 106 Member For: 18y 6m Posted 03/12/06 05:41 AM Author Share Posted 03/12/06 05:41 AM (edited) yeh mate, thanks for that.im thinking it will be the tubi or mani bolts.only one way to find out. And it doesnt hurt to throw in a $150 actuator in there at the same time that will help with boost control alot better to redline...cheersWill post more when I find out more for anyone intrested following the thread.Michael Edited 03/12/06 05:42 AM by wrxkilla Link to comment Share on other sites More sharing options...
