Hi Flow Turbo Installation
Romulus
  • Member For: 20y 2m 6d
During the week I had the turbo modified, along with the installation of a 3.5" dump pipe and 5" cat at APC Wangara. The turbo is modified with a bigger compressor wheel, machined compressor housing, wastegate port enlarged, bigger swing valve assembly, new bearings and VSR'ed.
Dynoed the car on Friday to gauge the difference in power. The car made a maximum of 328rwkw running 15-16psi boost and 780nm of torque with the stock turbo. I'm not an advocate of running stupid amounts of boost with the stock turbo, as the excess pressure is wasted due to the rediculous compressor outlet temps. Hence the upgrade.......
Power is now 347.4rwkw and 920nm of torque (will post torque graph tomorrow) at a modest 15.5psi. The initial boost flare has been fixed, car feels very strong. Turbo is noticably louder, with more induction noise. It spools up just as strong as the stock unit. That's an increase of 19rwkw and 140nm without raising boost over it's previous level.
I'm going to lift the boost to 18psi from it's current level, and see what results are produced. The bigger turbo is supposed to be good for an extra 200rwhp, and is good for up to 18 psi boost. I can't tune more boost into the car with the setup I have, and have to determine what is causing this. Perhaps it's the factory blow off valve bleeding off boost, maybe the factory solenoid can't handle the flow and pressure. I might try an eboost controller to see how it goes.
It's off to the drags in the next few weeks sporting MT ET Drag radials. 11.8 is what it did with 328rwkw on street tyres so it should run a low 11, hopefully.
It's a fine line though running a low 11 and getting banned from the Motorplex if it manages a high 10 :spoton:
Edited by M6 XR6T
  • Replies 94
  • Member For: 18y 10m 18d
Hi M6 XR6T
Your still a long way off Nizpro's Stage II + kit for BF Typhoons which produces 386 RWKW utilizing the stock OEM compressor wheel!!!!!!!
Your mods dont seem to be producing anywhere near a BF F6's potential and definitely lack cohesion ...
Check Nizpro's website and view the stats of Angelo's 386 RWKW BF F6 :spit:
cheers
Hi M6 XR6T
cheers
Thanks for the feedback.
I don't think it's that far off Nizpro's stage II kit, if any at all. From memory, Angelo's car dynoed 253rwkw stock. That's 23rwkw more than what we're seeing on Dyno Dynamic dynos. What time does their F6 run? The strip is a good lie detector, and dispells any rwkw myths. We all know that rwkw figures mean :spoton: , and are easy to make/fudge.
As for potential, it's the quickest F6 in WA, the third quickest on these forums, with the other 2 being in Sydney from memory. And that was before the turbo mods. Remember, I setup the car and tune it myself, without having to draw on the resources of other's in the automotive trade. I'm in the building trade by profession, not a mechanic. You won't find me on the phone to other shops every 5 minutes to figure stuff out.
I'm still trying to find the stats and track backed results for their F6, like they have of their Territory.
Edited by M6 XR6T
Yeah mate but he is doing things his way. Good luck with it mate.
Scotty
Thanks Scotty. Nothing quite like a dyno racer trying to tell other's how it's done.
The track results speak for themselves.
Guest
This topic is now closed to further replies.
