Ba To Be Bf'ed
Ninka
  • 2 months later...
  • 4 months later...
  • Member For: 15y 6m 1d
I keep getting told by various people that the conversion can be done without changing so many things.
They tell me that all you need to do is rewire the BA loom to fit the BF's ZF gearbox, with the addition of maybe another wire or two, and then re flash the BA computer so it can interface with the ZF gearbox.
Now, I am a bit skeptical of what these people are telling me. Is there any truth in what they are saying? :makedeal:
Now a question I have, what is the minimum work/changes required to get a BF 6 speed into a BA?
Edited by hayythere
  • 4 months later...
  • 1 year later...
  • Member For: 15y 4m 6d
Sweet, shows what mechanical ingenuity can do :buttrock: Maybe afterwards you could be thinking about strengthening the BA rear end (quite weak) ie. maybe source BF bits and pieces, as they have been strengthened, extra bolts, etc.
My brain says the next gen falcon will have awd + 3.5 ecoboost like they have in the states, excited? :stirthepot:
  • 5 months later...
  • Member For: 13y 8m 12d
Hi Buddy, currently getting by BA FG'd. Done the full hog with entire dash, body wiring looms, new FG Motor, new FG 6Spd, ABS/DSC. Did you
have any need to replace your ABS Wheel sensors? I'm assuming you had the BA Bosch 5.3 module originally, and swapped it out for the BF's ABS unit?
I'm unsure if the BF runs a Bosch 5.3 or a Bosch 8.0, but the FG Runs a Bosch 8.1 which I've installed in my BA. The BA wheel speed sensors are
apparently incompatible with the FG Bosch 8.1. In the rear, I've managed to install FG speed sensors, but the front ones are too much trouble to mount.
FG wheel speed sensors are mounted inside the actual FG wheel hub, while BA/BF run them external on the suspension uprights.
Can you tell me what Bosch module version you are running (part number would be great). Do you have traction and ABS?
Which brake lines did you need to add? My BA ABS Modulator had no lines running to the rear brakes (NO TC), so I just installed these 2 extra lines from a BF. I didn't replace the other 4 ABS lines that run to the master cylinder. Am I missing something? Cheers.
  • 3 months later...
  • 2 weeks later...
  • Member For: 14y 2m 18d
Just bringing this back to life, I have blown the engine in my BA turbo auto ute, and can get a complete BF Typhoon motor with 6 speed auto, wiring(not sure what), ecm etc.
Would this be an easier conversion than done by the original poster??
I am not sure of what other bits are available from the Phoon.
Or do I just get an FG motor, and use my 4speed.
