Ba To Be Bf'ed
Ninka
  • Member For: 19y 3m 13d
AWD conversion..... :welcome2:
Like in the GTR's so that it can be turned off when ever you wish.
Imagine what a 4oorwkw 6 speed auto Awd F6 would go like with a 2 step/launch controll.
Would be great
And I've got a woodie thinking about it .....
hrm.. I said that out loud didnt I?
d.
  • Member For: 21y 11m
After changing the transmission and converting my car to BF specification, it was today time to get my initial tune dyno'ed to see if I could crack the 350 rwkw barrier.
Initial run showed 321 rwkw, but after a bit of "adjustment" Simon cracked a 360 rwkw, so I'm very happy with that.
To make it 100% safe, I now have 2 tunes to choose from, one @ 358 rwkw and one @ 355 rwkw :spoton:
The differenc is that the boost is controlled slightly differently, and one tune is probably faster in outright acceleration (like the drags) and the other is better on the street.
Considering that I run stock pistons, I am extremely happy with the result, as I always aimed for the 350 rwkw mark :crybaby:
  • 7 months later...
  • Member For: 18y 7m 5d
OK I will attampt to explain!
When the trans leaves the factory, it has the software loaded which is compatible with the car where it is going to be installed, pretty much like the PCM gets the software to fit the car model and engine.
The TCM then is able to communicate via the CAN network (contrary to the 4 speed which is unable to communicate anything other than temperature), and when the car is started, the TCM looks for the software in the PCM, as the PCM and TCM work closely together managing the car during driving conditions.
If the software code in the PCM does not match what the TCM expects to see, it will report an error, and go into limp mode.
At this stage Ford dealers and anybody else is not able to change the version of the software in the trans, and so the only option is to make sure that the PCM software is a perfect match to what the TCM expects, and the only way to do this is to have a PCM software which is identical to the car where the transmission came from originally.
This can be achieved by either getting the PCM from the car where the trans came out, or making sure you have exactly the same PCM software to be loaded from somewhere else.
Hope this makes sense :bangcomputer:
Hi Allan,
Can you or anybody tell me if a ZF 6 speed auto from a BF Tornado will communicate happily when installed into a BF ZF 6 speed Typhoon? Im assuming there should be no problem between the PCM and TCM communicating since they are so similar in spec but am I assuming wrong?
All knowledgeable info appreciated
Cheers
  • 9 months later...
I probably spent over $10k on this conversion, but that was getting almost everything brand new, except for the ZF trans. Being a pioneer aint cheap :sharon:
If the right donor car can be found, I would think this could be done a lot cheaper now, as ZF equipped cars are not as rare as nearly 2 years ago when I started looking into this.
  • 3 weeks later...
  • 3 months later...
